[Qgis-user] Reduce the file size of the shape file
krishna Ayyala
ayyalakrishna at gmail.com
Tue Jun 29 17:26:24 PDT 2021
Nicolas,
Thanks for your reply. Changing the field format and saving to a different
file format did not work for me. Just now, I noticed that, Whenever I
select one line feature for the "ShortestPath" shapefile, I see the
following message at the bottom left corner of the window. For example:
"2148 feature(s) selected on layer shortest path. i.e. More than one
features appear at the bottom left corner for each line that I select. I am
trying to figure out how this will appear as 1 feature instead of 2148
features.The tools such as simplify and dissolve did not work for me.
Regards.
On Tue, Jun 29, 2021 at 4:43 PM Nicolas Cadieux <njacadieux.gitlab at gmail.com>
wrote:
> Hi,
> To my knowledge no. You could simplify the geometries but that would
> probably come with a resolution penalty (missing nodes). You could perhaps
> change the field data type. For example, an int data type will probably
> use less space than a float with a 16 decimal value. A text field can be
> reduced to the minimum size needed. You can also try to save the file
> under an other name. Depending on where the file was created and used,
> saving the file could “permanently delete” some previous deleted
> components. Can you use another file format?
> Nicolas Cadieux
> https://gitlab.com/njacadieux
> Le 29 juin 2021 à 15:53, krishna Ayyala <ayyalakrishna at gmail.com> a
> écrit :
> Hello,
> I have a "Streets" shape file of a state with about 12000 lines. For the
> same geographic area I have "Blocks_Centroids" shape file of about 6000
> points. I ran the tool as shown below. It resulted in a shapefile
> "ShortestPath" with 6000 lines. The size of the "Streets" shape file with
> 12000 lines is 5000 KB. Whereas the size of the output shape file
> "ShortestPath" with only 6000 lines is 270,000 KB. Is there a way to reduce
> the file size? The reason is I need to upload this in a different platform
> which cannot accept shapefiles larger than 10,000 KB.
> <image.png>
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210629/60f7f183/attachment-0001.html>
