[Qgis-user] QGIS Server, Lizmap / OpenLayer, QGIS2Web
    Alessandro Pasotti
    apasotti at gmail.com
    Wed Jun 30 08:11:53 PDT 2021
On Wed, Jun 30, 2021 at 4:11 PM Gerald Kogler <geraldo at servus.at> wrote:
> Hi,
> qgis2web exports a static version of your QGIS project to web using
> OpenLayers or Leaflet as webmap technologies. It gives you some options
> on export, furthermore you could take the exported code and customize it
> furthermore. It produces pure HTML+JS+CSS so you could host it on any
> server.
> One limitation is that all your data is exported as GeoJSON, so it's
> only suitable for limited amount of data as loading of big files could
> be quite slow on web.
> QGIS Server needs a more powerful server infrastructure as you have to
> install QGIS Server package with all it's dependencies. It has the big
> advantage that it serves QGIS projects with all it's symbology exactly
> as they are shown on desktop. But you have to code your own web viewer,
> for example using OpenLayers.
That's not entirely correct: since 3.16 QGIS Server provides you a simple
catalog and map viewer out of the box:
https://docs.qgis.org/3.16/en/docs/server_manual/services.html#qgis-server-catalog
No need for additional software.
WFS3 also has a (even more simpler) integrated map viewer.
Regards.
Alessandro Pasotti
QCooperative:  www.qcooperative.net
ItOpen:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210630/32f0551a/attachment.html>
