[Qgis-user] How to convert multiple features to single Feature - Shape file
    krishna Ayyala
    ayyalakrishna at gmail.com
    Wed Jun 30 12:34:30 PDT 2021
Tiago,
Thanks for your reply. Actually my shapefile is a polyLine. It is not a
polygon. My polyline shape file had about 6000 lines. When I ran
'multiparts to single parts" It resulted in a shapefile which also had 6000
lines. I was hoping it to be simplified to 30 or 40 lines but that did
not happen.
Regards.
On Tue, Jun 29, 2021 at 8:56 PM <tiago.moraessilva at hotmail.com> wrote:
> Good evenning.
>  In the tool box have e toll (multiparts to single parts). Will go break
> those multiples polygons in single parts.
> I hope help you e sorry my bad English.
> Regards
> Em 29 de jun. de 2021 22:06, krishna Ayyala <ayyalakrishna at gmail.com>
> escreveu:
> I have a line shapefile named "ShortestPath.shp". Whenever I select one
> line feature for the "ShortestPath" shapefile, I see the following message
> at the bottom left corner of the window. For example: "9 feature(s)
> selected on layer shortest path. i.e. More than one features appear at the
> bottom left corner for each line that I select.
>  Is there a way, whenever I select one line feature, It should appear as
> one line feature at the bottom left corner. The tools such as simplify and
> dissolve did not work for me.
> Regards.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210630/c2d7c66b/attachment.html>
