[Qgis-user] QGISserver 3.16 - WFS cascade getfeatureinfo and WMS cascade legend
Eugenio Trumpy frippe12573 at hotmail.com
Mon Mar 1 02:44:28 PST 2021
Hi all,
in the last month I experienced some issues on the different vQGISserver versions:
  *   firstly I had QGISserver 2.18 where WFS cascade getfeatureinfo was solved following this: https://github.com/qgis/QGIS/issues/41292 and https://github.com/qgis/QGIS/issues/25847, while WMS cascade getfeatureinfo and getlegend doesn't work. Here the mailinglist discussion: http://osgeo-org.1560.x6.nabble.com/qgisserver-for-publishing-external-WFS-td5456132.html
  *   then I updated to QGISserver 3.16. I couldn't update to 3.18 version because the server is Ubuntu 18.04 (not 20.04). Thus, now WMS cascade getfeatureinfo works fine, still not getlegend. The WFS cascade unfortunately doesn't work again. The only clue in the qgisserver.log is these lines:
11:26:51 WARNING Server[15710]: <ServiceExceptionReport version="1.3.0" xmlns="http://www.opengis.net/ogc">
 <ServiceException code="Service configuration error">Service unknown or unsupported. Current supported services (case-sensitive): WMS WFS WCS WMTS SampleService, or use a WFS3 (OGC API Features) endpoint</ServiceException>
</ServiceExceptionReport>
and
11:26:52 WARNING [15710]: Warning: error parsing post data as XML: at line 1, column 1: error occurred while parsing element. Assuming urlencoded query string sent in the post body.
and
11:30:12 WARNING Server[15710]: WMS capabilities document not found in cache
Please consider that in Lizmap framework if for a third party layer I chose 'get images directly from wms server' - in this case the legend is shown but not the map and consequently the getfeatureinfo doesn't work. That's weird!
Any hint?
Eugenio
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210301/53d39d1f/attachment.html>
