[Qgis-user] sry for greenhorn problem...
Helen Willems willems.helen at googlemail.com
Tue Mar 2 09:02:29 PST 2021
Dear experts!
I think I have a real "greenhorn problem", but nevertheless can´t solve
it on my own...
I used to work with QGIS 3.10 and wanted to use the UMEP Plugin, but
following error message occured:
Ein Fehler trat bei der Ausführung von Python-Code auf:
      RuntimeError: module compiled against API version 0xe but this
      version of numpy is 0xd
RuntimeError: module compiled against API version 0xe but this version
of numpy is 0xd
Python-Version: 3.7.3 (default, Mar 27 2019, 09:23:15) [Clang 10.0.1
(clang-1001.0.46.3)] QGIS-Version: 3.10.4-A Coruña A Coruña, 10bc9f2ff2
        Python-Pfad:
  * /Users/helenwillems/Library/Application
    Support/QGIS/QGIS3/profiles/default/python/plugins/geometric_attributes
  * /Applications/QGIS3.10.app/Contents/MacOS/../Resources/python
  * /Applications/QGIS3.10.app/Contents/MacOS/../Resources/python/plugins
  * /Applications/QGIS3.10.app/Contents/Frameworks/Python.framework/Versions/Current/lib/python3.7/site-packages/geos
  * /Applications/QGIS3.10.app/Contents/Resources/python
  * /Users/helenwillems/Library/Python/3.7/lib/python/site-packages
  * /Applications/QGIS3.10.app/Contents/Frameworks/Python.framework/Versions/Current/lib/python37.zip
  * /Applications/QGIS3.10.app/Contents/Frameworks/Python.framework/Versions/Current/lib/python3.7/lib-dynload
Then I updated QGIS to QGIS-LTR (3.16.4) and tried to install the UMEP
plugin again, but then this error message poped up:
Konnte Erweiterung 'UMEP' nicht laden aufgrund eines Fehlers beim Aufruf
der classFactory() Methode
      ModuleNotFoundError: No module named 'osr'
Traceback (most recent call last):   File
"/Applications/QGIS-LTR.app/Contents/MacOS/../Resources/python/qgis/utils.py",
line 334, in _startPlugin     plugins[packageName] =
package.classFactory(iface)   File
"/Users/helenwillems/Library/Application
Support/QGIS/QGIS3/profiles/default/python/plugins/UMEP/__init__.py",
line 34, in classFactory     from .UMEP import UMEP   File
line 792, in _import     mod = _builtin_import(name, globals, locals,
fromlist, level)   File "/Users/helenwillems/Library/Application
Support/QGIS/QGIS3/profiles/default/python/plugins/UMEP/UMEP.py", line
42, in     from .UMEPDownloader.umep_downloader import
UMEP_Data_Download   File
Support/QGIS/QGIS3/profiles/default/python/plugins/UMEP/UMEPDownloader/umep_downloader.py",
line 41, in     import osr   File
fromlist, level) ModuleNotFoundError: No module named 'osr'
Python-Version: 3.8.7 (default, Feb 10 2021, 09:04:08) [Clang 12.0.0
(clang-1200.0.32.29)] QGIS-Version: 3.16.4-Hannover Hannover, 81ba6c0826
        Python-Pfad:
  * /Applications/QGIS-LTR.app/Contents/MacOS/../Resources/python
  * /Applications/QGIS-LTR.app/Contents/MacOS/../Resources/python/plugins
  * /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/click_plugins-1.1.1-py3.8.egg
  * /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/patsy-0.5.1-py3.8.egg
  * /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/cftime-1.2.1-py3.8-macosx-10.13.0-x86_64.egg
  * /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/pandas-1.1.0-py3.8-macosx-10.13.0-x86_64.egg
  * /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/geopandas-0.8.1-py3.8.egg
  * /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/GDAL-3.2.1-py3.8-macosx-10.13.0-x86_64.egg
  * /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/Rtree-0.9.4-py3.8.egg
  * /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/matplotlib-3.3.0-py3.8-macosx-10.13.0-x86_64.egg
  * /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/rasterio-1.1.5-py3.8-macosx-10.13.0-x86_64.egg
  * /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/netCDF4-1.5.4-py3.8-macosx-10.13.0-x86_64.egg
  * /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/Pillow-7.2.0-py3.8-macosx-10.13.0-x86_64.egg
  * /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/scipy-1.5.1-py3.8-macosx-10.13.0-x86_64.egg
  * /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/affine-2.3.0-py3.8.egg
  * /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/numba-0.50.1-py3.8-macosx-10.13.0-x86_64.egg
  * /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/opencv_contrib_python-4.3.0.36-py3.8-macosx-10.13.0-x86_64.egg
  * /Applications/QGIS-LTR.app/Contents/MacOS/lib/python38.zip
  * /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/numpy-1.20.1-py3.8-macosx-10.13.0-x86_64.egg
  * /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/pyproj-2.6.0-py3.8-macosx-10.13.0-x86_64.egg
  * /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/snuggs-1.4.7-py3.8.egg
  * /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/Fiona-1.8.13.post1-py3.8-macosx-10.13.0-x86_64.egg
  * /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/lib-dynload
  * /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/statsmodels-0.11.1-py3.8-macosx-10.13.0-x86_64.egg
Can anybody help me?
I am really not an qgis expert, so would be pleased if someone could try
to help me in lets say "easy wording"?!
Hope to get some help! thx in advance..
Helen
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210302/376200bc/attachment.html>
