[Qgis-user] Do GPX files contain CRS information?
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Fri Mar 5 02:12:17 PST 2021
Hi Jeremy,
as far as I can remember, the CRS of waypoints is by default EPSG 4326,
no matter what you change in the settings of the device (changes just
alter display of coordinates on the device). But I haven't touched a
garmin for ages (yuk!) and do the stuff with my phone.
Your garmin seems to be a rather old model, cause with garmins from the
last 10 years or so, there was no need to use GPSbable to import the
data, but they just create gpx themselves.
It is quite uncommon to produce gpx files with other CRS than EPSG:4326,
so better import it into QGIS and reproject it to a new non-gpx file
format with the CRS of choice.
Hope that helps
Bernd
On 05.03.21 06:02, jeremy benwell wrote:
> Hi,
> I was wondering if GPX files contain CRS information? I saved some
> waypoints in my garmin gps and then used GPSBabel to upload those waypoints
> to my computer and create a GPX file. The map datum on my gps was set to
> GDA 94. Does my GPX file contain the CRS that my GPS was set to when I
> saved the waypoints (i.e. GDA 94) and if so do I need to make sure my QGIS
> project CRS is set to GDA 94 also?
> Any help would be much appreciated thank you!
> Cheers,
> Jeremy
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210305/f5cf0b3e/attachment.html>
