[Qgis-user] Trimble GeoXT 2005 Accuracy
Garth Fletcher
garth at jacqcad.com
Tue Mar 9 09:01:31 PST 2021
Nicolas Cadieux wrote:
> Kirk could be on the right track. You could try PPP using this site. You will need to create a user name and password. Then, you upload the Rinex file. I am 99% sure you can process point from outside of Canada.
I routinely use CSRS PPP to post process RINEX files from Southern New
Hampshire (43°N, 72°W).
Using an iGage iG3s (L1/L2 dual frequency, GPS + GLONASS) recording at
5 second epochs in forested areas, from post processing I get
30 minute recordings, 95% error ellipses < 1 meter
10 hour recordings, 95% error ellipses < 2 cm
CSRS-PPP site is
<https://webapp.geod.nrcan.gc.ca/geod/tools-outils/ppp.php?locale=en>
enter your email address
select Static and which NAD 83 epoch you want, or ITRF
Submit a RINEX file (.zip compressing the file is encouraged)
they will email back a detailed report
You can submit for 1 of 3 levels of post processing
ultra-rapid : submit > 90 minutes after end of recording
rapid: submit > 24 hours after end of recording
final: submit ~ 3 weeks after end of recording
Major part of corrections are in ultra-rapid, the higher levels provide
further refinements.
FYI: Trimble provides occupation planning aids at
<https://www.gnssplanning.com/#/charts>
just enter your location and date and it shows you the DOP as
a function of the hour of day.
Cordially,
Garth Fletcher
