[Qgis-user] Georeferencer GDAL - Tool - What is the meaning of the scaling factor in the Info
Kirk Schmidt kirk at nortekresources.com
Thu Mar 11 08:15:19 PST 2021
Hallo Michael:
I assume you are referring to the parameters in the lower part of the
georeferencing window? I qset up a test georeferencing and the screen
shot is below.
In this case, the values are the transformation parameters based on the
4 GCP's I used.  The value after the | are the coordinates of the cursor
measured from the top left corner.
Is this what you are referring too?
If the values are in your main map view, something has gone wrong in
your georefrencing and perhaps you do not have enough GCP or one of your
coorinates is wrong.  Try overlaying some additional vector or raster
data to confirm your image is in the right spot.
Kirk Schmidt
On 3/11/2021 10:47 AM, Michael Werner Maur wrote:
> Hello,
> I use the Georeferencer in the QGis Raster dialog för a long time. But
> yet I need further and detailed information about the quality
> parameters of the  transformation.
> For example I did a Helmert Transformation and find in the lower part
> of my desktop the parameters. There are two scaling factors for each
> coordinate axis, but they  are as the following value (0,05325...)
> ...I expected something in relation to the original scale of the
> scanned raster map (f.e. 1 : 1250 -> 0,0008).
> It will be very helpful, if there is a explanation to it ! Thanx a lot !
> Mit freundlichen Grüßen
> Im Auftrag
> Michael Maur
> Michael Maur
> Fachgruppenleiter 2.1
> VERMESSUNGS- UND KATASTERAMT OSTEIFEL-HUNSRÜCK
> Am Wasserturm 5a
> 56727 Mayen
> Telefon 02651 9582-120
> Telefax 02651 9582-400
> michael.maur at vermkv.rlp.de
> www.vermka-osteifel-hunsrueck.rlp.de
> Das Thema Datenschutz ist für uns eine wichtige Angelegenheit. Bitte
> beachten Sie unsere geltenden Datenschutzbestimmungen
> <https://lvermgeo.rlp.de/de/wichtige-Informationen/datenschutz> und
> unsere datenschutzrechtlichen Vorgaben bei Bewerbungsverfahren.
> <https://lvermgeo.rlp.de/fileadmin/lvermgeo/pdf/wir_ueber_uns/Datenverarbeitung_in_Bewerberverfahren.pdf>
> Qgis-user mailing list
Kirk Schmidt, MScF, BScF, RPF
General Manager
Nortek Resource Solutions Inc.
RR # 1
Thorburn, NS
B0K 1W0
Tel (902) 922.3607
Email: kirk at nortekresources.com
Web: www.nortekresources.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210311/9a22b0f4/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210311/9a22b0f4/attachment.png>
