[Qgis-user] Combing Vector Layers - With Attributes
Bo Victor Thomsen bo.victor.thomsen at gmail.com
Fri Mar 12 02:05:40 PST 2021
You can use processing algorithm "refactor fields" on the layer(s) that
have fields to be changed. This operation will give you a temporary
file/layer the same number of columns and -names as the original layer,
but with column type(s) redefined by you.
Afterwards you can merge the temporary file/layer with the other layers
Just be sure to have the latest (functioning) version of QGIS installed:
3.16.3. From the error message you included, I suspect you have an older
version of QGIS installed. I tried to merge 2 layers using QGIS 3.16.3
and the result was a new layer that contained the merged layers. If
there was a data discrepancy the result values were null's (but no
run-time errors)
Med venlig hilsen / Kind regards
Bo Victor Thomsen
Den 12-03-2021 kl. 10:04 skrev Springfield Harrison:
> Thanks Bo,
> I tried a sample run but it failed:
> "TAG field in layer Tree Table All 2 PntType has different data type
> than in other layers (String instead of integer)
> Execution failed after 1.20 seconds"
> It looks like it can't handle differing data types and won't offer
> choices for merging fields.  I wonder if there are other tools?
> Thanks again . . . .
> Cheers, Spring
> On 12/Mar/2021 00:48, Bo Victor Thomsen wrote:
>> Menu "Vector" -> "Data management tools" -> "Merge vector layers"
>> Bo Victor Thomsen
>> Den 12-03-2021 kl. 09:35 skrev Springfield Harrison:
>>> t shapefile) of trees to which I n
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210312/a8729918/attachment.html>
