[Qgis-user] Combing Vector Layers - With Attributes
    Springfield Harrison
    stellargps at gmail.com
    Sat Mar 13 00:31:58 PST 2021
Hello Bo et al,
Thanks very much.  I upgraded to 3.16.4 with some improvement. Fields in
the source but not present in the target were lost.
However, the Refactor tool worked well.  By making field names identical
in the source and the target I was able to append new records to the
master file by copy and paste, didn't need the Merge Layers tool.  I
prefer not to create too many files.
Thanks again . . . . .
Cheers, Spring
On 12/Mar/2021 02:05, Bo Victor Thomsen wrote:
> You can use processing algorithm "refactor fields" on the layer(s)
> that have fields to be changed. This operation will give you a
> temporary file/layer the same number of columns and -names as the
> original layer, but with column type(s) redefined by you.
> Afterwards you can merge the temporary file/layer with the other layers
> Just be sure to have the latest (functioning) version of QGIS
> installed: 3.16.3. From the error message you included, I suspect you
> have an older version of QGIS installed. I tried to merge 2 layers
> using QGIS 3.16.3 and the result was a new layer that contained the
> merged layers. If there was a data discrepancy the result values were
> null's (but no run-time errors)
> Med venlig hilsen / Kind regards
> Bo Victor Thomsen
> Den 12-03-2021 kl. 10:04 skrev Springfield Harrison:
>> Thanks Bo,
>> I tried a sample run but it failed:
>> "TAG field in layer Tree Table All 2 PntType has different data type
>> than in other layers (String instead of integer)
>> Execution failed after 1.20 seconds"
>> It looks like it can't handle differing data types and won't offer
>> choices for merging fields.  I wonder if there are other tools?
>> Cheers, Spring
>> On 12/Mar/2021 00:48, Bo Victor Thomsen wrote:
>>> Menu "Vector" -> "Data management tools" -> "Merge vector layers"
>>> Bo Victor Thomsen
>>> Den 12-03-2021 kl. 09:35 skrev Springfield Harrison:
>>>> t shapefile) of trees to which I n
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210313/31988909/attachment-0001.html>
