[Qgis-user] Combing Vector Layers - With Attributes
Kirk Schmidt kirk at nortekresources.com
Fri Mar 12 07:13:11 PST 2021
Hi Springer
You could try joining the databases using a common field assuming the
second one does not have new point features.  However, I expect you are
adding new point features.
In that case, I usually write a little python script to generate a new
set of features in the update layer that matches those of the master
layer.  I then recalculate the values of the new features before
dropping the initial set of fields. You can use Graphical Modeler to
generate a model and access through the Processing Toolbox> Models Group.
If you send me to sample shapefiles, I can put it together if you are
not familiar with the Graphical Modeler.
Kirk Schmidt
On 3/12/2021 4:35 AM, Springfield Harrison wrote:
> Hello All,
> I have a master database (point shapefile) of trees to which I need to
> add new records frequently.  The two files have different (but
> similar) attribute lists.  I need to combine them and add the new
> attributes into the appropriate SHP database columns.
> Copying and pasting records from the new file into the master list
> does work but if the fields are not identical, no attributes are
> brought into the master file.
> Is there a way to import the new records into their corresponding
> fields in the master file?
> I've searched for help on this to no avail.  Manifold GIS handles this
> very well, setting up a field matching dialogue but I would prefer to
> keep the process within QGIS.
> Thanks very much for any ideas . . . .
> Cheers, Springfield Harrison
> Qgis-user mailing list
Kirk Schmidt, MScF, BScF, RPF
General Manager
Nortek Resource Solutions Inc.
RR # 1
Thorburn, NS
B0K 1W0
Tel (902) 922.3607
Email: kirk at nortekresources.com
Web: www.nortekresources.com
