[Qgis-user] Raster Layer Symbology Problem
    Martin Bittens
    martin.bittens at gmx.de
    Fri Mar 12 03:30:02 PST 2021
Hello Sebastian,
thank you for your response. Yes indeed, for me the coloring style you
showed would be an option. This style is what I get in GRASS GIS as
well. But😁,
what I would prefer in QGIS is this (as provided by QGIS 3.16.4 LTR):
So I hope that in future QGIS versions, the user will have the choice
between the different display options. As far as I understood the
discussions in the links you sent there is something going on in order
to add an option for selecting the new  or the old display style.
Unfortunately, I am not an expert in that programming stuff and
therefore I don't know how to apply what there is explained. I will wait
and see what the next QGIS versions offer for displaying raster gradient
legends. And I will keep the QGIS 3.16.4 LTR with special care not
loosing the display style I showed above.
Regards
Martin
Am 3/10/2021 um 5:54 PM schrieb Sebastian Gutwein:
> Martin,
> I agree with your assessment.
> I assume the assumption of the designers (thank you Nyall Dawson et al
> for all of your amazing work) was that if you were displaying a
> continuous raster you would want a continuous legend as well.
> As shown by your issue and in the links I shared with you the reality
> is that this doesn't fit all use cases.
> I am considering writing up a feature request to address those issues.
> Unless you want to?
> To help me understand your use case more would a legend that was
> continuous but had numerical values at each "break" work for you? An
> example of this is in this tutorial
> https://www.ecodiv.earth/post/legend-for-continuous-raster-in-qgis-composer/
> <https://www.ecodiv.earth/post/legend-for-continuous-raster-in-qgis-composer/>
> -Bas
> On Wed, Mar 10, 2021 at 2:34 PM Martin Bittens <martin.bittens at gmx.de
> <mailto:martin.bittens at gmx.de>> wrote:
>     Sebastian, Bernd,
>     thanks a lot for your response. I checked the links Sebastian
>     sent. As far as I could see displaying data in the legend as a
>     continuum is a new feature in QGIS 3.18 which replaced the
>     previous method displaying data in the legend as categories (as
>     QGIS 3.16.4 is still doing - fortunately. Otherwise it would be
>     difficult producing maps in ongoing projects in a consistent
>     layout). And obviously there is no option available switching
>     between the old and the new display method. Personally I think it
>     was not a good decision giving up completely the categorical
>     display in the legend. In particular if you would work with
>     multiple colors and a large range of values, there is no way to
>     allocate map colors to the corresponding values, or vice versa.
>     So, I hope that the next QGIS version will include an option which
>     allows selecting the method how to  display the data, as continuum
>     or categorized.
>     Regards
>     Martin
>     Am 3/9/2021 um 4:18 PM schrieb Sebastian Gutwein:
>>     Martin,
>>     I think this may be the result of the new feature
>>     https://qgis.org/en/site/forusers/visualchangelog318/#feature-gradient-ramp-based-legends
>>     <https://qgis.org/en/site/forusers/visualchangelog318/#feature-gradient-ramp-based-legends>
>>     Which is exciting for me becasue that is how I would like to have
>>     my continious data display. But it sounds like that is not what
>>     you are interested in. I have not tried 3.18 myself so don't know
>>     if there is a workaround.
>>     It does look like there are some links to discussions in the
>>     comments of this stack exchange question.
>>     gis.stackexchange.com/questions/388843/qgis-3-18-override-raster-gradient-legends
>>     <http://gis.stackexchange.com/questions/388843/qgis-3-18-override-raster-gradient-legends>
>>     gis.stackexchange.com/questions/388154/how-to-get-back-discrete-raster-legend-symbols-in-qgis-3-16
>>     <http://gis.stackexchange.com/questions/388154/how-to-get-back-discrete-raster-legend-symbols-in-qgis-3-16>
>>     twitter.com/ThomasG77/status/1365255399927140355
>>     <http://twitter.com/ThomasG77/status/1365255399927140355>
>>     On Tue, Mar 9, 2021 at 7:54 AM Bernd Vogelgesang
>>     <bernd.vogelgesang at gmx.de <mailto:bernd.vogelgesang at gmx.de>> wrote:
>>         Without testing I would say it's a bug. Quite some bugs went
>>         into 3.18
>>         unnoticed and unfortunately, it's not  communicated on the
>>         landing page.
>>         Next regular point release will be in 10 days, but for urgent
>>         stuff, you
>>         should better use 3.16.
>>         On 09.03.21 13:32, Martin Bittens wrot:
>>         > Hello QGIS User List, i
>>         > I already sent this message but it was not posted, so it is
>>         here again.
>>         > Hopefully it works now.
>>         > I am still struggling with the problem creating a legend
>>         for a raster
>>         > layer. Usually I am working with the following settings in
>>         order to
>>         > colorize a calculated raster layer (e.g. after applying
>>         v.surf.idw on a
>>         > point data set):
>>         > - rendering type: singleband pseudocolor
>>         > - interpolation: linear
>>         > - mode: equal interval
>>         > In QGIS 3.18.0:
>>         > Selecting an appropriate color ramp and applying a
>>         classification in,
>>         > e.g., 5 classes, I see in the "Layer Properties -
>>         Symbology" window the
>>         > 5 colored classes separately and the corresponding 5 values
>>         (in my case
>>         > temperatures) for each color coding. But in the "Layer
>>         Panel" the legend
>>         > shows the color coding as a continuum and only the first
>>         and last value
>>         > of the value range appears. The same thing happens in the
>>         layout manager
>>         > when I create a layout for printing which includes a legend.
>>         > In QGIS 3.16.4 LTR and previous versions:
>>         > Doing the same I get the 5 color classes separately and the
>>         > corresponding values for each of the 5 classes in the
>>         "Legend Panel"as
>>         > well as in the layout manger.
>>         > My question: Is this a bug in the new QGIS version or does
>>         QGIS 3.18 not
>>         > provide this functionality anymore?
>>         > Thanks a lot for a comment.
>>         > Regards
>>         > Martin
>>         > This email has been checked for viruses by Avast antivirus
>>         software.
>>         > https://www.avast.com/antivirus
>>         <https://www.avast.com/antivirus>
>>         > _______________________________________________
>>         > Qgis-user mailing list
>>         > Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>         > List info:
>>         https://lists.osgeo.org/mailman/listinfo/qgis-user
>>         <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>>         > Unsubscribe:
>>         List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>         Unsubscribe:
>     <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient&utm_term=icon>
>     	Virus-free. www.avast.com
>     <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient&utm_term=link>
>     <#m_726336712862281711_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
This email has been checked for viruses by Avast antivirus software.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210312/5ec3a929/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210312/5ec3a929/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210312/5ec3a929/attachment-0003.png>
