[Qgis-user] Create circle with diameter in QGIS
Andreas Neumann
a.neumann at carto.net
Fri Mar 12 05:21:32 PST 2021
Ah - and don't forget that you need to finish the circle with the
right-mouse button!
So the steps are (more or less):
- enable editing
- enable advanced digitizing tools (the button with square and ruler)
- enable the circle tool (e.g. "Add Circle by a Center Point and Another
Point" tool)
- click in the canvas to set the circle center
- press "d" for distance and enter your radius (e.g. 5)
- press right mouse button to finish the circle
Hope this helps,
Andreas
On 2021-03-12 14:08, Andreas Neumann wrote:
> Hi Madeline,
> You need to enable the "Advanced Digitizing mode/panel". See
> https://docs.qgis.org/3.16/en/docs/user_manual/working_with_vector/editing_geometry_attributes.html#the-advanced-digitizing-panel
> for details.
> The shortcut "d" (distance) is your friend. When this mode is activated
> you can enter distances (like your radius) with the keyboard and QGIS
> will constrain to these values.
> You need to invest a bit of time to understand all the construction
> modes, but once you get it, it is quite powerful.
> Greetings,
> Andreas
> On 2021-03-12 13:37, Madeline Krohn wrote:
>> Dear QGIS Team,
>> I would like to create a circle whose diameter is 75 metres. I am
>> using QGIS version 3.16.3-Hannover.
>> My procedure so far has been like this:
>> 1. create a new shapefile layer -> geometry type: polygon
>> 2. in edit mode of this layer: add circle with centre and another
>> point
>> --> How can I change the radius/diameter of the circle afterwards or
>> is there another possibility to create a circle with diameter
>> directly?
>> Thank you very much and best regards
>> Madeline
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210312/915427d3/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210312/915427d3/attachment-0001.png>
