[Qgis-user] No transform available between XXX and EPSG:4326 when using non-Earth projections
Even Rouault
even.rouault at spatialys.com
Thu Mar 18 14:03:42 PDT 2021
Sebastian,
I can reproduce the 2 error messages you got. There's indeed something
in QGIS that tries a terrestrial reprojection and should be fixed, but I
don't think this is really critical apart of the annoyance of being
spammed about that. Please file a QGIS issue to track this. That said, I
managed to do a non-Earth reprojection by adding a custom CRS with the
following WKT definition:
GEOGCRS["MARS Geographic",
DATUM["D_MARS",
ELLIPSOID["MARS",3396000,0,
LENGTHUNIT["metre",1,
ID["EPSG",9001]]]],
PRIMEM["Reference meridian",0,
ANGLEUNIT["degree",0.0174532925199433,
ID["EPSG",9122]]],
CS[ellipsoidal,2],
AXIS["longitude",east,
ORDER[1],
ID["EPSG",9122]]],
AXIS["latitude",north,
ORDER[2],
ID["EPSG",9122]]]]
and selecting it as the project CRS. Using ESRI:104905 (GCS_Mars_2000)
seems to also work (I haven't deeply checked but I do get a reprojected
raster and geographic coordinates), but you'll get each time the
warnings about the 2 terrestrial coordinate operations. Hopefully in
coming months, I'll be able to ingest the IAU catalog into the PROJ
database as well.
Even
Le 18/03/2021 à 21:07, Sebastian Walter a écrit :
> Hi,
> Since Version 3.X I'm not able to perform transformations on planetary
> (non-Earth) data (from e.g. Mars or Mercury, example dataset:
> https://maps.planet.fu-berlin.de/mex4/h1104_0000.ihs.53.tif). The
> error message is:
> No transform is available between SINUSOIDAL MARS and Custom CRS:
> GEOGCRS["unknown",DATUM["unknown",ELLIPSOID["WGS 8….
> proj_create_operations: Source and target ellipsoid do not belong to
> the same celestial body
> No transform available between SINUSOIDAL MARS and EPSG:4326
> The consequence is that transformations to lat/lon are not possible
> any more. With the older QGis there was no problem like this. My
> suspect is the "new" Proj6 database layout, but the above error
> messages also point to the fact there there is some EPSG:4326
> projection hard-coded into Qgis.
> Is anybody successfully using Qgis with non-Earth data and proper
> transformations?
> Thanks for any advise...
> Sebastian
> Qgis-user mailing list
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210318/aef59096/attachment.html>
