[Qgis-user] Map styles changing when I export as image
    Charles Dixon-Paver
    charles at kartoza.com
    Sun Mar 21 02:02:44 PDT 2021
If you select the large map frame is it not connected to a map them in the
frame properties? Themes are a pretty robust way to control this behaviour
actually...
On Sun, 21 Mar 2021, 10:44 jeremy benwell, <jeremybenwell at gmail.com> wrote:
> Hi all,
> I'm having some trouble with exporting my map as an image. When I try to
> export my map as an image all the styles change (see images below, I had to
> shrink size to make email within 100kb limit so they are a bit blurry). The
> dpi I choose is 100. I'm guessing the problem has something to do with what
> layers are selected in the project tab but can't seem to figure out how
> exactly. Is there some way to stop the project tab from feeding information
> to the print layout tab so i can export the print layout tab as an image
> exactly as is.
> Any help would be much appreciated.
> Cheers,
> Jeremy
> How I want my map to be exported as an image
> [image: imgonline-com-ua-CompressToSize-uIfjmSKXaLw1ocp.jpg]
> My project layers
> [image: imgonline-com-ua-CompressToSize-tRIxoZUAwx6sH.jpg]
> How my map is actually exported as an image
> [image: imgonline-com-ua-CompressToSize-VePdVaL4aS.jpg]
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210321/8d8c2c03/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210321/8d8c2c03/attachment-0003.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210321/8d8c2c03/attachment-0004.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210321/8d8c2c03/attachment-0005.jpg>
