[Qgis-user] Draw Rectangle from three points - can it include distance?
Loïc Bartoletti
lbartoletti at tuxfamily.org
Wed May 5 23:50:07 PDT 2021
You can set the distance in the advanced digitzing panel [1]. All shape
digitizing tools can be used in combination with this panel.
Regards.
Loïc
Le 06/05/2021 à 06:58, Johanna Botman a écrit :
> Hi,
> I need to create thousands of polygons for a layer. Sadly, they will
> all be hand drawn. The Draw Rectangle From Three Points is fabulous,
> but I was wondering if there was a way that I could easily see the
> measurements of the rectangle as I draw using that tool? Or is there
> another tool or method I could use?
> *Johanna Botman*
> Assets / GIS Officer – Melton City Council
> The information in this message is privileged and confidential,
> intended only for the use of the individual or entity named above. If
> you are not the intended recipient you are hereby notified to delete
> the message and that any dissemination, copying or use of its content
> is strictly prohibited. If you have received this message in error
> please notify the Melton City Council.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210506/92f6528b/attachment.html>
