[Qgis-user] Draw Rectangle from three points - can it include distance?
Johanna Botman
johannab at melton.vic.gov.au
Wed May 5 23:55:01 PDT 2021
Hi Loic,
Thanks for your answer. I saw a brief description of that as a possibility, but when I tried, it looked quite complicated by using x and y coordinates.
I'll have another look
Johanna Botman
Assets / GIS Officer - Melton City Council
From: Loïc Bartoletti [mailto:lbartoletti at tuxfamily.org]
Sent: Thursday, 6 May 2021 4:50 PM
To: Johanna Botman <johannab at melton.vic.gov.au>; qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Draw Rectangle from three points - can it include distance?
You can set the distance in the advanced digitzing panel [1]. All shape digitizing tools can be used in combination with this panel.
Regards.
Loïc
Le 06/05/2021 à 06:58, Johanna Botman a écrit :
I need to create thousands of polygons for a layer. Sadly, they will all be hand drawn. The Draw Rectangle From Three Points is fabulous, but I was wondering if there was a way that I could easily see the measurements of the rectangle as I draw using that tool? Or is there another tool or method I could use?
Johanna Botman
The information in this message is privileged and confidential, intended only for the use of the individual or entity named above. If you are not the intended recipient you are hereby notified to delete the message and that any dissemination, copying or use of its content is strictly prohibited. If you have received this message in error please notify the Melton City Council.
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user<https://aus01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fqgis-user&data=04%7C01%7Cjohannab%40melton.vic.gov.au%7Cadf77cbbc484417215be08d9105b32fe%7C3c254d694e4641f79684759dce781c6a%7C0%7C0%7C637558806618380885%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C0&sdata=JNn2ijEgTcdwSr78HqAHUbWV6%2FfEv%2FJEa1MiWEKuKH4%3D&reserved=0>
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user<https://aus01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fqgis-user&data=04%7C01%7Cjohannab%40melton.vic.gov.au%7Cadf77cbbc484417215be08d9105b32fe%7C3c254d694e4641f79684759dce781c6a%7C0%7C0%7C637558806618380885%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C0&sdata=JNn2ijEgTcdwSr78HqAHUbWV6%2FfEv%2FJEa1MiWEKuKH4%3D&reserved=0>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210506/a8d14211/attachment-0001.html>
