[Qgis-user] Draw Rectangle from three points - can it include distance?
Alexandre Neto
senhor.neto at gmail.com
Thu May 6 03:20:22 PDT 2021
I have just posted this link on another thread:
https://twitter.com/AlexNetoGeo/status/856395509367525376?s=19
Advanced digitising is really what you need. Press 'd', type the distance
you want, press enter to lock it.
Best regards,
Alexandre Neto
A quinta, 6/05/2021, 07:55, Johanna Botman <johannab at melton.vic.gov.au>
escreveu:
> Hi Loic,
> Thanks for your answer. I saw a brief description of that as a
> possibility, but when I tried, it looked quite complicated by using x and y
> coordinates.
> I’ll have another look
> *Johanna Botman*
> Assets / GIS Officer – Melton City Council
> *From:* Loïc Bartoletti [mailto:lbartoletti at tuxfamily.org]
> *Sent:* Thursday, 6 May 2021 4:50 PM
> *To:* Johanna Botman <johannab at melton.vic.gov.au>;
> qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] Draw Rectangle from three points - can it
> include distance?
> Hi,
> You can set the distance in the advanced digitzing panel [1]. All shape
> digitizing tools can be used in combination with this panel.
> Regards.
> Loïc
> Le 06/05/2021 à 06:58, Johanna Botman a écrit :
> Hi,
> I need to create thousands of polygons for a layer. Sadly, they will all
> be hand drawn. The Draw Rectangle From Three Points is fabulous, but I was
> wondering if there was a way that I could easily see the measurements of
> the rectangle as I draw using that tool? Or is there another tool or method
> I could use?
> *Johanna Botman*
> The information in this message is privileged and confidential, intended
> only for the use of the individual or entity named above. If you are not
> the intended recipient you are hereby notified to delete the message and
> that any dissemination, copying or use of its content is strictly
> prohibited. If you have received this message in error please notify the
> Melton City Council.
> Qgis-user mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://aus01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fqgis-user&data=04%7C01%7Cjohannab%40melton.vic.gov.au%7Cadf77cbbc484417215be08d9105b32fe%7C3c254d694e4641f79684759dce781c6a%7C0%7C0%7C637558806618380885%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C0&sdata=JNn2ijEgTcdwSr78HqAHUbWV6%2FfEv%2FJEa1MiWEKuKH4%3D&reserved=0>
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://aus01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fqgis-user&data=04%7C01%7Cjohannab%40melton.vic.gov.au%7Cadf77cbbc484417215be08d9105b32fe%7C3c254d694e4641f79684759dce781c6a%7C0%7C0%7C637558806618380885%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C0&sdata=JNn2ijEgTcdwSr78HqAHUbWV6%2FfEv%2FJEa1MiWEKuKH4%3D&reserved=0>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210506/cf72652a/attachment.html>
