[Qgis-user] tfw Parameters
Alexandre Neto
senhor.neto at gmail.com
Fri May 14 01:43:47 PDT 2021
This has to do with projections. Putting it as simple as possible, because
the earth is "round" any try to flatten it (a projection) implies some form
of distortion. Using different projections means different distortions.
When we reproject a raster, that distortion difference is applied to each
pixel, which leads to different pixel sizes and shape.
Best regards,
Alexandre Neto
Users Support
www.qcooperative.net
A terça, 11/05/2021, 07:55, ludwig <ludwig at kni-online.de> escreveu:
> Perhaps because pixels must not necessarily be quadratic? A grafic in Din
> A1 has to sides with a relation of sqrt(2), 594x841mm, I think qgis tries
> to fill the area without rest, which is not possible with quadratic pixels.
> Just a thought...
> Von meinem/meiner Galaxy gesendet
> -------- Ursprüngliche Nachricht --------
> Von: "Preuß, Sylvia" <Sylvia.Preuss at obk.de>
> Datum: 11.05.21 07:55 (GMT+01:00)
> An: 'Marco Lechner' <mlechner at bfs.de>, "Quantum Gis mailinglist (
> qgis-user at lists.osgeo.org)" <qgis-user at lists.osgeo.org>
> Betreff: Re: [Qgis-user] tfw Parameters
> Hi Marco,
> thank you, the original data is from a SpatiaLite database with EPSG:25832
> Sylvia
> *Von:* Marco Lechner <mlechner at bfs.de>
> *Gesendet:* Montag, 10. Mai 2021 16:33
> *An:* Preuß, Sylvia <Sylvia.Preuss at obk.de>; Quantum Gis mailinglist (
> qgis-user at lists.osgeo.org) <qgis-user at lists.osgeo.org>
> *Betreff:* AW: tfw Parameters
> I’d guess the original TIFF is not EPSG:25832 and is based on a different
> elipsoid?
> best regards
> Marco
> *Von:* Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] *Im Auftrag
> von *Preuß, Sylvia
> *Gesendet:* Montag, 10. Mai 2021 15:51
> *An:* Quantum Gis mailinglist (qgis-user at lists.osgeo.org) <
> *Betreff:* [Qgis-user] tfw Parameters
> Hi all,
> I exported vectordata DIN A1 TIFF in EPSG 25832, scale 1:25000 and got
> different Pixelsizes in the worldfile.
> 2.116892375645
> 0.000000000000
> 0.000000000000
> -2.116681770004
> 391333.999992426485
> 5663925.500010723248
> Does anybody know how come?
> Thank you
> Sylvia
> * Der E-Mail-Dienst des Oberbergischen Kreises dient ausschließlich der
> dienstlichen Kommunikation. Senden Sie deshalb keine E-Mails privaten
> Inhalts an E-Mail-Adressen des Oberbergischen Kreises.*
> Es wird darauf hingewiesen, dass neben der Person, an die Ihre E-Mail
> gerichtet ist, auch deren Vertretung im Amt einen unmittelbaren Zugriff auf
> Ihre Nachricht hat. Für Berufsgeheimnisträger und besondere Funktionsträger
> gelten abweichende Regelungen.
> Es wird außerdem darauf hingewiesen, dass die Kommunikation per E-Mail
> ohne Authentifizierung und Verschlüsselung unsicher ist, da für
> unberechtigte Dritte grundsätzlich die Möglichkeit der Kenntnisnahme und
> Manipulation besteht.
> Es wird deshalb keine Verantwortung für den Inhalt dieser Nachricht
> übernommen, da eine Manipulation nicht ausgeschlossen werden kann.
> Obwohl alle angemessenen Vorkehrungen getroffen wurden, um
> sicherzustellen, dass Anlagen dieser E-Mail virusgeprüft sind, wird
> empfohlen, anhängende Dateien vor dem Öffnen durch Ihr eigenes
> Virus-Programm zu prüfen, da keinerlei Haftung für Schäden übernommen wird,
> die infolge etwaiger Software-Viren entstehen könnten.
> Der Inhalt dieser E-Mail ist ausschließlich für die bezeichnete Person
> bestimmt. Wenn Sie nicht der vorgesehene Adressat dieser E-Mail oder dessen
> Vertretung sein sollten, beachten Sie bitte, dass jede Form der
> Kenntnisnahme, Veröffentlichung, Vervielfältigung oder Weitergabe des
> Inhalts dieser E-Mail unzulässig ist. In diesem Fall wird darum gebeten,
> sich mit der absendenden Person der E-Mail in Verbindung zu setzen.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210514/4287bd65/attachment.html>
