[Qgis-user] QGIS file version control
Alexandre Neto
senhor.neto at gmail.com
Fri May 14 11:50:32 PDT 2021
Hi Hugh,
Check this plugin to make you qgs files more trackable:
https://plugins.qgis.org/plugins/trackable_project_files/
Best regards,
Alexandre Neto
User support
www.qcooperative.net
A sexta, 14/05/2021, 18:03, Hugh Kelley <hghklly at gmail.com> escreveu:
> Hi,
> Is anyone aware of any thought or work put into version control for a qgis
> file?
> I had a look through the open issues on github and didn't turn anything
> up. I found some conversation about data versioning on stack overflow but
> nothing specific to the qgis file itself.
> Unzipping the qgz file and tracking the qgs file with git worked fairly
> smoothly for the few basic tests i just tried. it would become much more
> complicated as some other files get created for more complicated maps are
> built. For instance the .qgd files are binaries which aren't handled very
> well in git.
> If anyone is currently using git to version control their qgis projects i
> would be interested in hearing how they manage it and any best practices
> they could share.
> Thanks
> Hugh
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210514/679c2e21/attachment.html>
