[Qgis-user] QGIS file version control
Richard Duivenvoorde
rdmailings at duif.net
Sat May 15 03:01:43 PDT 2021
On 5/14/21 8:50 PM, Alexandre Neto wrote:
> Hi Hugh,
> Check this plugin to make you qgs files more trackable:
> https://plugins.qgis.org/plugins/trackable_project_files/ <https://plugins.qgis.org/plugins/trackable_project_files/>
THAT was exactly my experience when I recently put a projectfile on github to be able to easily share the styling of a big set of (national) geopackages [0]: the order of the attributes are totally unpredictable in standard QGIS: without changing anything, resaving a project, you get A LOT of 'edits' in your files.
Apparently this plugin has a solution for it (only looked to the description):
"Orders attributes in .qgs project files in a predictable order. This helps tracking QGIS project files in versioning systems like git."
It would be good to pull this into QGIS in my view, would that be easy?
Regards,
[0] https://github.com/rduivenvoorde/QGIS_top10nl_style
