[Qgis-user] QGIS file version control
Richard Duivenvoorde
rdmailings at duif.net
Sat May 15 03:41:24 PDT 2021
On 5/15/21 12:01 PM, Richard Duivenvoorde wrote:
> Apparently this plugin has a solution for it (only looked to the description):
> "Orders attributes in .qgs project files in a predictable order. This helps tracking QGIS project files in versioning systems like git."
Mmm, does partially work in my tests here, with this project
https://github.com/rduivenvoorde/QGIS_top10nl_style
some parts are still changing (I only zoomed/panned in between saves).
https://github.com/rduivenvoorde/QGIS_top10nl_style/commits/master/top10nlv2.qgs
For this project I specially saved the project to a .qgs file so I hoped it would be easier to track if others did some changes/pull requests in the styling (an old Dutch standard map styling).
Note: to be able to use the project, you have to download a 2,5Gb zip with geopackages from
https://service.pdok.nl/kadaster/top10nl/atom/v1_0/top10nl.xml
and unzip them in the data dir of the repo.
And you also need some fonts...
Regards,
