[Qgis-user] QGIS file version control
Greg Troxel
gdt at lexort.com
Sat May 15 05:13:40 PDT 2021
Richard Duivenvoorde <rdmailings at duif.net> writes:
> On 5/14/21 8:50 PM, Alexandre Neto wrote:
>> Hi Hugh,
>> Check this plugin to make you qgs files more trackable:
>> https://plugins.qgis.org/plugins/trackable_project_files/ <https://plugins.qgis.org/plugins/trackable_project_files/>
> THAT was exactly my experience when I recently put a projectfile on
> github to be able to easily share the styling of a big set of
> (national) geopackages [0]: the order of the attributes are totally
> unpredictable in standard QGIS: without changing anything, resaving a
> project, you get A LOT of 'edits' in your files.
> Apparently this plugin has a solution for it (only looked to the description):
> "Orders attributes in .qgs project files in a predictable order. This helps tracking QGIS project files in versioning systems like git."
> It would be good to pull this into QGIS in my view, would that be easy?
> Regards,
Do you mean:
It's a bug that qgis can save a project that is semantically equal in
textually different forms with reordering.
This plugin addresses that bug.
[implicitly, there's no reason to want arbitrary/variable ordering]
Therefore the plugin should just be folded in and be the normal
behavior?
That's how I see it, but I'm still newish so I may be missing something.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210515/a22bc3e6/attachment-0001.sig>
