[Qgis-user] Select data from a specific layer
Ujaval Gandhi ujaval at spatialthoughts.com
Mon May 17 23:29:38 PDT 2021
get_feature() will get you the feature.Your current expression will get you
the first feature from 'V_TB_ATTIVITA_PT_NR' layer where the "Colore" value
is 'N'. - I don't think that is what you want.  You need to query for a
feature from another layer that relates to the current feature, (using a
common field value).  Once you get the feature, you can use the
attributes(feature)['Colore'] to read the "Colore' field from that feature.
[image: Logo] <https://spatialthoughts.com/>
Ujaval Gandhi
Spatial Thoughts
mobile: +91-8095684687
email: ujaval at spatialthoughts.com
[image: LinkedIn icon] <https://www.linkedin.com/in/spatialthoughts/>  [image:
Twitter icon] <https://twitter.com/spatialthoughts>
On Tue, May 18, 2021 at 4:35 AM Delaz J <delazj at gmail.com> wrote:
> Hi Dario,
> Could you try with 'Colore' and not "Colore" (pay attention to the simple
> vs double quotes)?
> Regards,
> Harrissou
> Le 18/05/2021 à 00:41, Dario C a écrit :
>   Hi, thank you for your reply, but I still don't understand how to do...
> sorry
> i tried to write this code in colour expression, but I don't understand
> what "value" is in get_feature :
> CASE
> When
> get_feature('V_TB_ATTIVITA_PT_NR',"Colore",'N')='N' then color_rgb (0,0,0)
> When
> get_feature('V_TB_ATTIVITA_PT_NR',"Colore",'R')='R' then color_rgb
> (255,0,0)
> END
> Consider that I have a virtual field called "Colore" where I have 'N' or
> 'R' in case it is black or red color.
> Thank you for your kind availability.
> cheers
> Il giorno lun 17 mag 2021 alle ore 09:09 Ujaval Gandhi <
> ujaval at spatialthoughts.com> ha scritto:
>> You can select the layer under 'Plot Parameters' and its attributes will
>> be available in the expression. (see attached screenshot).
>> If you need to get the attribute from another layer, you can use the
>> get_feature() function to get feature from another layer by specifying the
>> layer name.
>> Ujaval Gandhi
>> Spatial Thoughts
>> On Mon, May 17, 2021 at 2:47 AM Dario <dario955i at gmail.com> wrote:
>>> Hi,
>>> I should get some data from a specific field of a specific layer but I’m
>>> stuck.
>>> I’m using “Data Ploty” plug-in and I’d like to customise the colour of
>>> the chart using expression.
>>> As I’m working on layout I can’t see any field into expression menu, so
>>> I need to call a specific layer and then the field.
>>> I’d like to write something like that but, of course, selecting the
>>> correct layer:
>>> CASE
>>> WHEN "Civici" = 'Neri' THEN color_rgb(0,0,0)
>>> ELSE color_rgb (255,0,0)
>>> END
>>> Thank you in advance.
>>> Cheers
>>> _
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Qgis-user mailing listQgis-user at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210518/40633150/attachment-0001.html>
