[Qgis-user] Layout page size variable?
    Tony Shepherd (FarmMaps NZ)
    tony at farmmaps.nz
    Thu May 20 15:17:03 PDT 2021
Hi Charles (& others)
Thanks for the advice guys.  I’ve come up with this, it works a treat.
[%'Scale 1:' || format_number(round(map_get(item_variables('Main-Map-1'), 'map_scale'),0),0)||
CASE
WHEN @layout_pagewidth IS 297 AND @layout_pageheight IS 210 THEN ' @ A4'
WHEN @layout_pagewidth IS 210 AND @layout_pageheight IS 297 THEN ' @ A4'
WHEN @layout_pagewidth IS 420 AND @layout_pageheight IS 297 THEN ' @ A3'
WHEN @layout_pagewidth IS 297 AND @layout_pageheight IS 420 THEN ' @ A3'
ELSE ' @ ???'
END%]
Cheers
Tony
Sent: Friday, 21 May 2021 9:46 am
To: Tony Shepherd (FarmMaps NZ) <tony at farmmaps.nz>
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Layout page size variable?
Yeah I am not aware of a variable for this... But page sizes are actually more complicated than they seem. You can emulate it pretty easily with something like the following expression on a layout as you suggested:
[%CASE
WHEN @layout_pagewidth IS 297 AND @layout_pageheight IS 210 THEN 'On A4 Landscape'
WHEN @layout_pagewidth IS 210 AND @layout_pageheight IS 297 THEN 'On A4 Portrait'
WHEN @layout_pagewidth IS 420 AND @layout_pageheight IS 297 THEN 'On A3 Landscape'
WHEN @layout_pagewidth IS 297 AND @layout_pageheight IS 420 THEN 'On A3 Portrait'
ELSE 'With page dimensions of ' || @layout_pagewidth || ' x ' || @layout_pageheight
END%]
On Thu, 20 May 2021 at 23:13, Tony Shepherd (FarmMaps NZ) <tony at farmmaps.nz <mailto:tony at farmmaps.nz> > wrote:
Hi All
Is there a variable that returns the page size of a print layout?
I would like to add the page size to the scale below so it reads something like “1:5,000 @ A3”
I can see variables for width and height, but not Page Size?
Or would I need to code in some ‘if’ &  ‘then’ statements using the width variables to arrive at the page size?
Cheers
Tony
Tony Shepherd  |  GeoSpatial / Mapping Manager
Ph 027 435 6193  |  E  <mailto:tony at farmmaps.nz> tony at farmmaps.nz
FarmMaps NZ, 3 Kerwood Place, Gore 9740
 <http://tonyshepherd8.wixsite.com/home>  <https://www.wunderground.com/personal-weather-station/dashboard?ID=ISTLGORE2>
Qgis-user mailing list
Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210521/c316f476/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210521/c316f476/attachment-0003.png>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210521/c316f476/attachment-0001.jpg>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210521/c316f476/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210521/c316f476/attachment-0005.png>
