[Qgis-user] Layout page size variable?
    John Layt
    j.layt at lparchaeology.com
    Fri May 21 01:43:26 PDT 2021
Not sure you can use it in this case, but if you're needing to find
standard page sizes and localised names from width x height measurements,
the Qt QPageSize class has useful lookup tools. See
https://doc.qt.io/qt-5/qpagesize.html.
Something like:
    id = QPageSize.id(QSizeF(width, height), QPageSize.Millimeters)
    name = QPageSize.name(id)
It does a fuzzy match on size within 3 points, and ignores orientation, so
should always get the right standard page size regardless.
Cheers!
John.
On Thu, 20 May 2021 at 23:17, Tony Shepherd (FarmMaps NZ) <tony at farmmaps.nz>
wrote:
> Hi Charles (& others)
> Thanks for the advice guys.  I’ve come up with this, it works a treat.
> [%'Scale 1:' || format_number(round(map_get(item_variables('Main-Map-1'),
> 'map_scale'),0),0)||
> CASE
> WHEN @layout_pagewidth IS 297 AND @layout_pageheight IS 210 THEN ' @ A4'
> WHEN @layout_pagewidth IS 210 AND @layout_pageheight IS 297 THEN ' @ A4'
> WHEN @layout_pagewidth IS 420 AND @layout_pageheight IS 297 THEN ' @ A3'
> WHEN @layout_pagewidth IS 297 AND @layout_pageheight IS 420 THEN ' @ A3'
> ELSE ' @ ???'
> END%]
> Cheers
> Tony
> *From:* Charles Dixon-Paver <charles at kartoza.com>
> *Sent:* Friday, 21 May 2021 9:46 am
> *To:* Tony Shepherd (FarmMaps NZ) <tony at farmmaps.nz>
> *Cc:* qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] Layout page size variable?
> Yeah I am not aware of a variable for this... But page sizes are actually
> more complicated than they seem. You can emulate it pretty easily with
> something like the following expression on a layout as you suggested:
> [%CASE
> WHEN @layout_pagewidth IS 297 AND @layout_pageheight IS 210 THEN 'On A4
> Landscape'
> WHEN @layout_pagewidth IS 210 AND @layout_pageheight IS 297 THEN 'On A4
> Portrait'
> WHEN @layout_pagewidth IS 420 AND @layout_pageheight IS 297 THEN 'On A3
> Landscape'
> WHEN @layout_pagewidth IS 297 AND @layout_pageheight IS 420 THEN 'On A3
> Portrait'
> ELSE 'With page dimensions of ' || @layout_pagewidth || ' x ' ||
> @layout_pageheight
> END%]
> On Thu, 20 May 2021 at 23:13, Tony Shepherd (FarmMaps NZ) <
> tony at farmmaps.nz> wrote:
> Hi All
> Is there a variable that returns the page size of a print layout?
> I would like to add the page size to the scale below so it reads something
> like “1:5,000 @ A3”
> I can see variables for width and height, but not Page Size?
> Or would I need to code in some ‘if’ &  ‘then’ statements using the width
> variables to arrive at the page size?
> Cheers
> Tony
> *Tony Shepherd*  *|*  GeoSpatial / Mapping Manager
> Ph 027 435 6193  *|*  E tony at farmmaps.nz
> FarmMaps NZ, 3 Kerwood Place, Gore 9740
> [image: FM_logo1_small (Custom)]
> <http://tonyshepherd8.wixsite.com/home>
> <https://www.wunderground.com/personal-weather-station/dashboard?ID=ISTLGORE2>
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210521/77d02d9a/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210521/77d02d9a/attachment.png>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210521/77d02d9a/attachment.jpg>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210521/77d02d9a/attachment-0001.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210521/77d02d9a/attachment-0002.png>
