[Qgis-user] Expressio too slow
Dario
dario955i at gmail.com
Thu Nov 4 05:38:51 PDT 2021
Both options are very slow. I think it’s not depending to the expression, but the main project.
Something always loading from the main server (oracle and other cababilities)
_
Il giorno 4 nov 2021, alle ore 13:26, Delaz J <delazj at gmail.com> ha scritto:
Hi
Dario, dDo you edit the expression in the text box or select all the text and press "Insert/edit expression" button? In the latter case, you open the expression dialog and afaik it does not try to update as you write.
read the hint at https://docs.qgis.org/3.22/en/docs/user_manual/print_composer/composer_items/composer_label.html#main-properties
Harrissou
Le 04/11/2021 à 12:57, Andrea Giudiceandrea a écrit :
>> Dario C Thu, 04 Nov 2021 03:43:08 -0700
>> Is there any way to stop calculation, write and re-launch calculation, in
>> order to write smoothly?
> Hi Dario,
> have you tried to comment out the expression, modify it and then uncomment it out?
> https://docs.qgis.org/3.22/en/docs/user_manual/expressions/expression.html#the-interface
> Regards.
> Andrea
> Qgis-user mailing list
