[Qgis-user] Expressio too slow
Dario C dario955i at gmail.com
Thu Nov 4 06:46:56 PDT 2021
Ok, I'm doing some test.
[image: image.png] Qgis is continuously updating only when I open the
layout, otherwise everything is going smoothly.
This legend has the following expression and I guess "Intersects"
probably requires this kind of updating and resource:
"[%aggregate( '*LayerID*','count',"*FIELD*","*FIELD*" ='*FEATURE*' AND
*intersects($geometry, at atlas_geometry)*)%]"
Il giorno gio 4 nov 2021 alle ore 13:38 Dario <dario955i at gmail.com> ha
scritto:
> Both options are very slow. I think it’s not depending to the expression,
> but the main project.
> Something always loading from the main server (oracle and other
> cababilities)
> _
> Il giorno 4 nov 2021, alle ore 13:26, Delaz J <delazj at gmail.com> ha
> scritto:
> Hi
> Dario, dDo you edit the expression in the text box or select all the text
> and press "Insert/edit expression" button? In the latter case, you open the
> expression dialog and afaik it does not try to update as you write.
> read the hint at
> https://docs.qgis.org/3.22/en/docs/user_manual/print_composer/composer_items/composer_label.html#main-properties
> Harrissou
> Le 04/11/2021 à 12:57, Andrea Giudiceandrea a écrit :
> >> Dario C Thu, 04 Nov 2021 03:43:08 -0700
> >> Is there any way to stop calculation, write and re-launch calculation,
> in
> >> order to write smoothly?
> > Hi Dario,
> > have you tried to comment out the expression, modify it and then
> uncomment it out?
> https://docs.qgis.org/3.22/en/docs/user_manual/expressions/expression.html#the-interface
> > Regards.
> > Andrea
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211104/0e367e28/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211104/0e367e28/attachment.png>
