[Qgis-user] LAS with extra dimensions and QGIS/Entwine
    Saber Razmjooei
    saber.razmjooei at lutraconsulting.co.uk
    Fri Nov  5 00:05:39 PDT 2021
It looks a bit odd indeed. I did a quick translate using PDAL and then the
translated file worked fine in QGIS:
pdal translate em2040_40111_05_23_2017_with_unc.las test.las
Best to file a QGIS bug.
Kind regards
Saber
On Thu, 4 Nov 2021 at 15:50, Eric Younkin - NOAA Federal <
eric.g.younkin at noaa.gov> wrote:
> Hello,
> Wondering if I could get some advice on LAS import in QGIS 3.20.2-Odense.
> I have a LAS that I have generated using laspy adding an extra float
> dimension ('uncertainty').  Example file below:
> https://drive.google.com/file/d/1LkY08eGLXjvBrV4eR-UzDVQz2hL_kufS/view?usp=sharing
> This file can be opened in laspy, LASTools and can be converted using
> 'entwine build' on the console to generate entwine data that can be dragged
> into QGIS for visualization.  What I can't seem to get work is dragging in
> the LAS file to QGIS to build the Entwine automatically.  It generates the
> Entwine directories but no conversion happens.  Is this a known issue?  Are
> extra dimensions not supported in the QGIS entwine process?
> Thanks,
> Eric
> Eric Younkin
> Physical Scientist
> NOAA OCS, Hydrographic Systems and Technology Branch
> 1315 East-West Highway
> N/CS11, Room 6604
> Silver Spring, MD 20910
> Office: 240-847-8208
> Cell: 828-331-8197
> Qgis-user mailing list
Saber Razmjooei
www.lutraconsulting.co.uk
+44 (0)7568 129733
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211105/cfaed5cb/attachment.html>
