[Qgis-user] LAS with extra dimensions and QGIS/Entwine
Eric Younkin - NOAA Federal
eric.g.younkin at noaa.gov
Fri Nov 5 06:26:25 PDT 2021
Thanks for the advice, I have submitted a ticket:
https://github.com/qgis/QGIS/issues/45903
Thanks,
Eric
On Fri, Nov 5, 2021 at 3:06 AM Saber Razmjooei <
saber.razmjooei at lutraconsulting.co.uk> wrote:
> It looks a bit odd indeed. I did a quick translate using PDAL and then the
> translated file worked fine in QGIS:
> pdal translate em2040_40111_05_23_2017_with_unc.las test.las
> Best to file a QGIS bug.
> Kind regards
> Saber
> On Thu, 4 Nov 2021 at 15:50, Eric Younkin - NOAA Federal <
> eric.g.younkin at noaa.gov> wrote:
>> Hello,
>> Wondering if I could get some advice on LAS import in QGIS 3.20.2-Odense.
>> I have a LAS that I have generated using laspy adding an extra float
>> dimension ('uncertainty'). Example file below:
>> https://drive.google.com/file/d/1LkY08eGLXjvBrV4eR-UzDVQz2hL_kufS/view?usp=sharing
>> This file can be opened in laspy, LASTools and can be converted using
>> 'entwine build' on the console to generate entwine data that can be dragged
>> into QGIS for visualization. What I can't seem to get work is dragging in
>> the LAS file to QGIS to build the Entwine automatically. It generates the
>> Entwine directories but no conversion happens. Is this a known issue? Are
>> extra dimensions not supported in the QGIS entwine process?
>> Thanks,
>> Eric
>> Eric Younkin
>> Physical Scientist
>> NOAA OCS, Hydrographic Systems and Technology Branch
>> 1315 East-West Highway
>> N/CS11, Room 6604
>> Silver Spring, MD 20910
>> Office: 240-847-8208
>> Cell: 828-331-8197
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Saber Razmjooei
> www.lutraconsulting.co.uk
> +44 (0)7568 129733
Eric Younkin
Physical Scientist
N/CS11, Room 6604
Cell: 828-331-8197
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211105/1d8e3d35/attachment.html>
