[Qgis-user] QGIS 3.22 - GRASS Init-Error
Martin Bittens martin.bittens at gmx.de
Wed Nov 10 04:19:43 PST 2021
Hello Allister,
I just installed the latest nightly version of QGIS 3.22 (which is
3.22.0.76) using the OSGEO4W installer. This version is working with the
GRASS 7 plugin and the GRASS 7 algorithms.
Regards
Martin
Am 11/10/2021 um 8:40 AM schrieb Martin Bittens:
> Hello Alister,
> in the meantime I did an update on a second computer from QGIS 3.20.3
> to QGIS 3.22.0, and from QGIS 3.16.11 to 3.16.13 using the OSGEO4W
> installer. The result is:
> QGIS 3.22.0 displays the GRASS init error, the GRASS 7 plugin cannot
> be used, the GRASS processing algorithms are working.
> QGIS 3.16.13 is working without any problems. Both, the GRASS 7 plugin
> and the GRASS processing algorithms can be used.
> As far as I understood the GRASS 7 plugin in QGIS 3.22 'want to see' a
> GRASS version which is not installed whereas the GRASS 7 plugin which
> came with QGIS 3.16.13 is satisfied with the installed GRASS version.
> But I do not have any idea how telling the GRASS 7 plugin of QGIS 3.22
> that it should take what is installed.
> Regards
> Martin
> Am 11/10/2021 um 7:43 AM schrieb Alister Hood:
>>     Date: Mon, 8 Nov 2021 22:31:30 -0300
>>     From: Martin Bittens <martin.bittens at gmx.de>
>>     To: qgis-user at lists.osgeo.org
>>     Subject: [Qgis-user] QGIS 3.22 - GRASS Init-Error
>>     Message-ID: <8f3b2b78-bfc8-1040-bf42-873b8ec46d47 at gmx.de>
>>     Content-Type: text/plain; charset=UTF-8; format=flowed
>>     Hello QGIS User Group!
>>     Today I did the update from QGIS 3.20 to 3.22 using the Win10 64bit?
>>     installer 'osgeo4w-setup.exe' provided on the QGIS homepage. When I
>>     opened the new QGIS version I received the following warning:
>>      ?GRASS init error : Problem in GRASS initialization, GRASS
>>     provider and
>>     plugin will not work : Module built against version
>>     2021-10-11T09:56:15+00:00 but trying to use version
>>     2021-11-01T10:26:16+00:00. You need to rebuild GRASS GIS or untangle
>>     multiple installations.
>>     Obviously, something does not fit. But what?
>>     Are there any ideas? I also did the update from 3.16.11 to
>>     3.16.13 (the
>>     LTR versions) and did not this problem...
>>     Thank you
>>     Martin
>> I installed 3.22 today using the standalone Windows installer, not
>> the OSGEO4W installer, and I got the same error on startup.
>> Both the Grass Plugin and Provider show in the plugin manager as
>> loaded, but I haven't tried using them to confirm it is truly broken.
>> I note that the Grass processing algorithms do still work.
>> Regards,
>> Alister
>> Qgis-user mailing list
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient&utm_term=icon>
> 	Virus-free. www.avast.com
> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient&utm_term=link>
> <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211110/5d62450b/attachment.html>
