[Qgis-user] QGIS 3.22 - GRASS Init-Error
Martin Bittens
martin.bittens at gmx.de
Wed Nov 10 03:40:26 PST 2021
Hello Alister,
in the meantime I did an update on a second computer from QGIS 3.20.3 to
QGIS 3.22.0, and from QGIS 3.16.11 to 3.16.13 using the OSGEO4W
installer. The result is:
QGIS 3.22.0 displays the GRASS init error, the GRASS 7 plugin cannot be
used, the GRASS processing algorithms are working.
QGIS 3.16.13 is working without any problems. Both, the GRASS 7 plugin
and the GRASS processing algorithms can be used.
As far as I understood the GRASS 7 plugin in QGIS 3.22 'want to see' a
GRASS version which is not installed whereas the GRASS 7 plugin which
came with QGIS 3.16.13 is satisfied with the installed GRASS version.
But I do not have any idea how telling the GRASS 7 plugin of QGIS 3.22
that it should take what is installed.
Regards
Martin
Am 11/10/2021 um 7:43 AM schrieb Alister Hood:
> Date: Mon, 8 Nov 2021 22:31:30 -0300
> From: Martin Bittens <martin.bittens at gmx.de>
> To: qgis-user at lists.osgeo.org
> Subject: [Qgis-user] QGIS 3.22 - GRASS Init-Error
> Message-ID: <8f3b2b78-bfc8-1040-bf42-873b8ec46d47 at gmx.de>
> Content-Type: text/plain; charset=UTF-8; format=flowed
> Hello QGIS User Group!
> Today I did the update from QGIS 3.20 to 3.22 using the Win10 64bit?
> installer 'osgeo4w-setup.exe' provided on the QGIS homepage. When I
> opened the new QGIS version I received the following warning:
> ?GRASS init error : Problem in GRASS initialization, GRASS
> provider and
> plugin will not work : Module built against version
> 2021-10-11T09:56:15+00:00 but trying to use version
> 2021-11-01T10:26:16+00:00. You need to rebuild GRASS GIS or untangle
> multiple installations.
> Obviously, something does not fit. But what?
> Are there any ideas? I also did the update from 3.16.11 to 3.16.13
> (the
> LTR versions) and did not this problem...
> Thank you
> Martin
> I installed 3.22 today using the standalone Windows installer, not the
> OSGEO4W installer, and I got the same error on startup.
> Both the Grass Plugin and Provider show in the plugin manager as
> loaded, but I haven't tried using them to confirm it is truly broken.
> I note that the Grass processing algorithms do still work.
> Regards,
> Alister
> Qgis-user mailing list
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211110/c0b5ac4d/attachment.html>
