[Qgis-user] Atlas feature id not synchronised
    Dario C
    dario955i at gmail.com
    Fri Nov 12 06:39:09 PST 2021
thank you for your quick response.
atlas coverage layer is the building layer
Yes, with  $id = @atlas_featureid is working well!!! Thank you
Can you please explain, if you don't mind, why? I mean, what's
@atlas_featureid and why $id = @atlas_featureid solve the problem?
Il giorno ven 12 nov 2021 alle ore 15:04 Alexandre Neto <
senhor.neto at gmail.com> ha scritto:
> Hi Dario,
> If the atlas coverage layer is the buildings layer, then you can use:
> $id = @atlasfeatureid
> If not, if you have a common attribute called ID between the building
> layer and your coverage layer, you can use:
> "ID" =  attributes( @atlas_feature)['ID']
> Hope it helps
> Alexandre Neto
> User Support
> www.qcooperative.net
> On Fri, Nov 12, 2021 at 1:50 PM Dario <dario955i at gmail.com> wrote:
>> Hi,
>> I’m doing a report and it is happening something odd. I don’t know if it
>> a bug or something I’m not doing well (probably).
>> - I have a layer with an ID as integer and unique
>> - I have categorised my layer by rule, in order to show only the analysed
>> building: “ID=@atlasfeatureid+1”
>> - I’m using this ID as controller of my group report
>> - I have added a textfield to show some field and “atlasfeatureid+1” for
>> a double check
>> - first three pages are ok, after map and text are synchro, but the
>> categorised building does not work and indeed atlasfeatureid shows number
>> completely different with ID
>> I have no idea why :(
>> _
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211112/6db6c554/attachment.html>
