[Qgis-user] Atlas feature id not synchronised
Alexandre Neto
senhor.neto at gmail.com
Fri Nov 12 06:04:23 PST 2021
Hi Dario,
If the atlas coverage layer is the buildings layer, then you can use:
$id = @atlasfeatureid
If not, if you have a common attribute called ID between the building layer
and your coverage layer, you can use:
"ID" = attributes( @atlas_feature)['ID']
Hope it helps
Alexandre Neto
User Support
www.qcooperative.net
On Fri, Nov 12, 2021 at 1:50 PM Dario <dario955i at gmail.com> wrote:
> Hi,
> I’m doing a report and it is happening something odd. I don’t know if it a
> bug or something I’m not doing well (probably).
> - I have a layer with an ID as integer and unique
> - I have categorised my layer by rule, in order to show only the analysed
> building: “ID=@atlasfeatureid+1”
> - I’m using this ID as controller of my group report
> - I have added a textfield to show some field and “atlasfeatureid+1” for a
> double check
> - first three pages are ok, after map and text are synchro, but the
> categorised building does not work and indeed atlasfeatureid shows number
> completely different with ID
> I have no idea why :(
> _
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211112/c7ad7079/attachment.html>
