[Qgis-user] Project file format
Paul Wittle
paul.wittle at dorsetcouncil.gov.uk
Tue Nov 16 13:03:50 PST 2021
I will try that out; thank you so much for the pointer 😊
Paul
Sent: 16 November 2021 18:11
To: Paul Wittle <paul.wittle at dorsetcouncil.gov.uk>
Cc: qgis-user <qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] Project file format
Paul,
as far as the re-ordering of xml elements, I had a similar question about version control a while ago and Alexandre Neto helpfully suggested using this plug in which orders elements in a deterministic way to minimize reordering.
Hope it helps and thanks again to Alex for the original suggestion.
https://plugins.qgis.org/plugins/trackable_project_files/
On Tue, Nov 16, 2021, 12:52 PM Paul Wittle <paul.wittle at dorsetcouncil.gov.uk<mailto:paul.wittle at dorsetcouncil.gov.uk>> wrote:
I know people will probably ask “why?” in relation to this question but I’ve got a Powershell script that I use to create copies of some QGIS projects because I want to change the data source of a couple of layers between dev and test. Rather than do this in QGIS it is done as part of an automation hence using Powershell; I’ve had mixed results trying to load the QGIS project standalone and so Powershell felt simpler.
Anyway; the issue I’m getting is that Powershell is adding a space between the last />. So <title/> will become <title />. Is there a way to set QGIS so that the project files are saved with the spaces?
The other issue I’m getting is that the attributes in the elements seem to be moving depending on who saves it. This is when using QGIS; not Powershell.
So I save the project using QGIS and I get:
<qgis projectname=”” saveDateTime=”” saveUser=”” version=”” saveUserFull=””>
Someone else saves it on their device using QGIS and we get:
<qgis projectname=”” saveUser=”” saveUserFull=”” version=”” saveDateTime=””>
Is this expected as I would have thought that QGIS would have kept this consistent?
The version is "3.16.0-Hannover" for all the users.
The reason I’m asking is that the files are in source control and given it is XML I would have expected it to be easy to identify what someone changed but due to the issues above it tends to claim that almost everything was changed. This is just because all the attributes are reordered and the spaces are being added to the end of elements as well. I can live with it but I thought I’d ask if there is a setting I can use that will ensure that projects save consistently really?
Any tips would be appreciated but if it is too technical a question they my apologises.
Paul
This e-mail and any files transmitted with it are intended solely for the use of the individual or entity to whom they are addressed. It may contain unclassified but sensitive or protectively marked material and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All traffic may be subject to recording and/or monitoring in accordance with relevant legislation. Any views expressed in this message are those of the individual sender, except where the sender specifies and with authority, states them to be the views of Dorset Council. Dorset Council does not accept service of documents by fax or other electronic means. Virus checking: Whilst all reasonable steps have been taken to ensure that this electronic communication and its attachments whether encoded, encrypted or otherwise supplied are free from computer viruses, Dorset Council accepts no liability in respect of any loss, cost, damage or expense suffered as a result of accessing this message or any of its attachments. For information on how Dorset Council processes your information, please see www.dorsetcouncil.gov.uk/data-protection<http://www.dorsetcouncil.gov.uk/data-protection>
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211116/f0b972ef/attachment.html>
