[Qgis-user] Project file format
Jorge Gustavo Rocha
jgr at geomaster.pt
Wed Nov 17 02:25:06 PST 2021
Hi Paul,
1) I use pg_services. I just change one link (to the desired
pg_services.conf file) to change between prod and dev layers. I don't
have to change the QGIS project.
2) To find/replace parts of any XML file, I use the old xmlstarlet
command line tool. Using such tools, the order of the attributes is
irrelevant.
Regards,
Jorge
[1] http://xmlstar.sourceforge.net/doc/UG/xmlstarlet-ug.html
On 16/11/21 17:51, Paul Wittle wrote:
> Hi,
> I know people will probably ask “why?” in relation to this question
> but I’ve got a Powershell script that I use to create copies of some
> QGIS projects because I want to change the data source of a couple of
> layers between dev and test. Rather than do this in QGIS it is done as
> part of an automation hence using Powershell; I’ve had mixed results
> trying to load the QGIS project standalone and so Powershell felt
> simpler.
> Anyway; the issue I’m getting is that Powershell is adding a space
> between the last />. So <title/> will become <title />. Is there a way
> to set QGIS so that the project files are saved with the spaces?
> The other issue I’m getting is that the attributes in the elements
> seem to be moving depending on who saves it. This is when using QGIS;
> not Powershell.
> So I save the project using QGIS and I get:
> <qgis projectname=”” saveDateTime=”” saveUser=”” version=””
> saveUserFull=””>
> Someone else saves it on their device using QGIS and we get:
> <qgis projectname=”” saveUser=”” saveUserFull=”” version=””
> saveDateTime=””>
> Is this expected as I would have thought that QGIS would have kept
> this consistent?
> The version is "3.16.0-Hannover" for all the users.
> The reason I’m asking is that the files are in source control and
> given it is XML I would have expected it to be easy to identify what
> someone changed but due to the issues above it tends to claim that
> almost everything was changed. This is just because all the attributes
> are reordered and the spaces are being added to the end of elements as
> well. I can live with it but I thought I’d ask if there is a setting I
> can use that will ensure that projects save consistently really?
> Any tips would be appreciated but if it is too technical a question
> they my apologises.
> Paul
> This e-mail and any files transmitted with it are intended solely for
> the use of the individual or entity to whom they are addressed. It may
> contain unclassified but sensitive or protectively marked material and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use
> it, or disclose it to anyone else. If you have received this
> transmission in error please notify the sender immediately. All
> traffic may be subject to recording and/or monitoring in accordance
> with relevant legislation. Any views expressed in this message are
> those of the individual sender, except where the sender specifies and
> with authority, states them to be the views of Dorset Council. Dorset
> Council does not accept service of documents by fax or other
> electronic means. Virus checking: Whilst all reasonable steps have
> been taken to ensure that this electronic communication and its
> attachments whether encoded, encrypted or otherwise supplied are free
> from computer viruses, Dorset Council accepts no liability in respect
> of any loss, cost, damage or expense suffered as a result of accessing
> this message or any of its attachments. For information on how Dorset
> Council processes your information, please see
> www.dorsetcouncil.gov.uk/data-protection
> Qgis-user mailing list
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211117/e2ba1e47/attachment.html>
