[Qgis-user] Pictures rotated 90 degrees on composer
Dario
dario955i at gmail.com
Fri Nov 19 06:37:29 PST 2021
Solved with a batch action in Photoshop, just saving all the picture (overwrite) without any modification.
I think it is a problem of the picture taken by phone. You cannot see from width and height size the real orientation. They look portrait, but actually when I insert them (mostly, not all!) they are displayed rotated. 🤷🏽♂️
_
Il giorno 19 nov 2021, alle ore 14:02, Nicolas Cadieux <njacadieux.gitlab at gmail.com> ha scritto:
Yes, you can do an image rotation. Check out this section.
https://docs.qgis.org/3.22/en/docs/user_manual/print_composer/composer_items/composer_image.html#id9
Cheers
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 19 nov. 2021 à 02:23, Dario C <dario955i at gmail.com> a écrit :
> Hi,
> Sorry for bothering so much 😅
> I have a frame picture (portrait) on the report composer linked to the control layer parameter. It works well, each page has its own proper image, but they are sometimes rotated 90 degrees. I thought they were landscape instead of portrait, but actually window explorer shows me portrait orientation.
> Is there any way to force image orientation?
> Thank you
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211119/11bb497e/attachment.html>
