[Qgis-user] Pictures rotated 90 degrees on composer
    Nicolas Cadieux
    njacadieux.gitlab at gmail.com
    Fri Nov 19 07:21:38 PST 2021
Indeed
Pictures taken with some cameras have a tag indicating if they should be read in landscape or portrait.  If the tag is not recognized by the software or the OS, it will be shown in landscape by default. It gets complicated when the image is shown in portrait in the Windows user interface but in landscape in a software.  That is when you know you have a problem. XNview can also do those batch operations. The other option was to use the image rotation in the composer.
Cheers, nice to know you got it working.
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 19 nov. 2021 à 09:37, Dario <dario955i at gmail.com> a écrit :
> Solved with a batch action in Photoshop, just saving all the picture (overwrite) without any modification.
> I think it is a problem of the picture taken by phone. You cannot see from width and height size the real orientation. They look portrait, but actually when I insert them (mostly, not all!) they are displayed rotated. 🤷🏽♂️
> _
> Il giorno 19 nov 2021, alle ore 14:02, Nicolas Cadieux <njacadieux.gitlab at gmail.com> ha scritto:
> Hi,
> Yes, you can do an image rotation. Check out this section.
> https://docs.qgis.org/3.22/en/docs/user_manual/print_composer/composer_items/composer_image.html#id9
> Cheers
> Nicolas Cadieux
>>> Le 19 nov. 2021 à 02:23, Dario C <dario955i at gmail.com> a écrit :
>> Hi,
>> Sorry for bothering so much 😅
>> I have a frame picture (portrait) on the report composer linked to the control layer parameter. It works well, each page has its own proper image, but they are sometimes rotated 90 degrees. I thought they were landscape instead of portrait, but actually window explorer shows me portrait orientation.
>> Is there any way to force image orientation?
>> Thank you
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211119/d19a6bf3/attachment.html>
