[Qgis-user] Pictures rotated 90 degrees on composer
Jésahel Benoist
djes1975 at gmail.com
Sat Nov 20 01:45:05 PST 2021
Hi, we had this problem for a long time, in composer (!=forms). I've first
tried to add some script and special fields, but finally it's far easier
to correct all photos with XNView and its 'rotate by exif' function. See
https://newsgroup.xnview.com/viewtopic.php?t=1420#:~:text=To%20do%20this%2C%20you%20select,on%20the%20EXIF%20orientation%20flag
As it's a special JPEG function, it don't suffer from loss of quality and
it's faster.
Jésahel
Le ven. 19 nov. 2021 à 16:22, Nicolas Cadieux <njacadieux.gitlab at gmail.com>
a écrit :
> Indeed
> Pictures taken with some cameras have a tag indicating if they should be
> read in landscape or portrait. If the tag is not recognized by the
> software or the OS, it will be shown in landscape by default. It gets
> complicated when the image is shown in portrait in the Windows user
> interface but in landscape in a software. That is when you know you have a
> problem. XNview can also do those batch operations. The other option was to
> use the image rotation in the composer.
> Cheers, nice to know you got it working.
> Nicolas Cadieux
> https://gitlab.com/njacadieux
> Le 19 nov. 2021 à 09:37, Dario <dario955i at gmail.com> a écrit :
> Solved with a batch action in Photoshop, just saving all the picture
> (overwrite) without any modification.
> I think it is a problem of the picture taken by phone. You cannot see from
> width and height size the real orientation. They look portrait, but
> actually when I insert them (mostly, not all!) they are displayed rotated.
> _
> Il giorno 19 nov 2021, alle ore 14:02, Nicolas Cadieux <
> njacadieux.gitlab at gmail.com> ha scritto:
> Hi,
> Yes, you can do an image rotation. Check out this section.
> https://docs.qgis.org/3.22/en/docs/user_manual/print_composer/composer_items/composer_image.html#id9
> Cheers
> Nicolas Cadieux
> Le 19 nov. 2021 à 02:23, Dario C <dario955i at gmail.com> a écrit :
> Hi,
> Sorry for bothering so much 😅
> I have a frame picture (portrait) on the report composer linked to the
> control layer parameter. It works well, each page has its own proper image,
> but they are sometimes rotated 90 degrees. I thought they were landscape
> instead of portrait, but actually window explorer shows me portrait
> orientation.
> Is there any way to force image orientation?
> Thank you
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211120/47cfb4bb/attachment.html>
