[Qgis-user] Content Rotated but X Grid lines vertical and Y grid lines horizontal on Composer
jean Lukusa
lukusam at gmail.com
Fri Nov 19 10:06:38 PST 2021
Very helpful.
Jean Lukusa
B.Sc. Geology
Trained on Jorc Code
GIS Operator
+243812156128
Le ven. 19 nov. 2021 à 18:39, Nicolas Cadieux <njacadieux.gitlab at gmail.com>
a écrit :
> Hi,
> If you rotate the map windows, the rotate grid would also rotate. I guess
> one way would be to have two map windows. One with content but rotated,
> one empty, not rotated... That would give you incorrect coordinates
> though... The most likely possibility is that the map has a different CRS
> than the Grid CRS (you can specify the CRS for each grid) giving the
> impression that one is rotated and one is not.
> Nicolas
> On 2021-11-19 11:25 a.m., jean Lukusa wrote:
> Hi all,
> I have seen a map with content rotated to 320 degree but the X grid lines
> vertical and Y grid lines horizontal on the composer.
> So , would someone help me ?
> Jean Lukusa
> B.Sc. Geology
> GIS Operator
> +243812156128
> Qgis-user mailing listQgis-user at lists.osgeo.org
> Nicolas Cadieuxhttps://gitlab.com/njacadieux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211119/bd1d28f1/attachment.html>
