[Qgis-user] Does DWG work in 3.22? - RE: importing dwg/dxf
Michael Dufty MDufty at mbsenvironmental.com.au
Sun Nov 21 21:18:22 PST 2021
The older version of AutoCAD Civil3d I have includes AutoCAD map functions and definitely gives you options to include CRS information in the dwg outputs.  The problem is I think the same software is the only thing that will read that information, so I never bothered using that function.    The export to shape file feature is more useful.  Not sure how many versions of AutoCAD have that capacity, but I can't recall ever receiving any shape exports from AutoCAD.
Recent versions of QGIS seem to be handling dxf files really well, so I always convert to that before trying to open.  CADWizz is a very affordable converter that often seems to work when other options fail.
Michael Dufty
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Jeff Sonnentag
Sent: Monday, 22 November 2021 12:07 PM
To: Bernd Vogelgesang <bernd.vogelgesang at gmx.de>; Nicolas Cadieux <njacadieux.gitlab at gmail.com>; Greg Troxel <gdt at lexort.com>; Boaz Bar Ilan <boazprosie at gmail.com>
Cc: qgis-user <qgis-user at lists.osgeo.org>
Subject: [Qgis-user] Does DWG work in 3.22? - RE: importing dwg/dxf
Somebody must get the same quality of “engineering” that we do here.  :D
The last item received was in feet and aligns with California State Plane Zone 6, but they chopped off the first digit of both “X” and “Y” for everything.  Who knows why.  Maybe things run faster for them with 6 digit coordinates rather than 7 digit ones like you mentioned.  (???)
Anyway, when I tried the simple drag and drop into QGIS 3.22 it never worked.  Always an error message about invalid data, even after I used DWG Trueview to convert it to the oldest possible versions (97/98 and 2000).  I did manage to get it in AFTER converting the DWG to a DXF with an online conversion site.  That DXF could be drug (I hate the word “dragged” – seems along the lines of “runned”) into QGIS and appeared OK.  Export to a shapefile and then do some affine adjustment magic and things can be worked with.
Is there a reason that a DWG can’t be dropped into QGIS 3.22 but a DXF can?  Are there some DWG versions that just don’t work?  I thought I got a DWG to appear OK in 3.16, but maybe I just imagined it and used a DXF before too. . . .
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211122/692361b3/attachment-0001.html>
