[Qgis-user] QGIS project templates and PostGIS connections
Bo Victor Thomsen bo.victor.thomsen at gmail.com
Mon Nov 22 12:11:35 PST 2021
This answer is somewhat old; there might be a better solution:
https://gis.stackexchange.com/questions/247454/simplify-postgis-authentication-process-from-qgis
and directory .qgis2 is replaced by a profile directory:  Menu item
"Settings"->"Open Active Profile Folder"
Med venlig hilsen / Kind regards
Bo Victor Thomsen
Den 22-11-2021 kl. 20:35 skrev Frank Broniewski:
> Hi fellow QGIS user!
> I am scratching my head on the following problem. I want to create a
> QGIS project template which has PostGIS layers in it. I want to be
> able to pass this template to other users who might use them for
> different tasks.
> The problem now is the connection string to the PostGIS database. When
> using the authentication manager each PostGIS connection gets its own
> ID which in turn is then referenced in the connection string to the
> layer. But now this ID to the PostGIS connection is different for each
> user, so the stored connection string in the template is not valid
> anymore. And each user has his own credentials for logging into
> PostGIS as well.
> I see that I can give a custom ID to a connection in the
> authentication manager, but it is locked by default, so I am hesitant
> to unlock it. But is this a viable option? Create the PostGIS
> connection under the same ID for each user?
> There's also the PostgreSQL connection service file [1] which might be
> an option? Does anyone have some experience to share, especially when
> talking Windows PC?
> How do you manage PostGIS connections for "simple" users on a somewhat
> larger scale? I am talking about 20 users, just enough to be annoying
> enough for manual deployment ...
> Many thanks for any tips,
> Frank
> [1] https://www.postgresql.org/docs/12/libpq-pgservice.html
> Qgis-user mailing list
