[Qgis-user] Tip for managing heavy data
Dario dario955i at gmail.com
Fri Nov 26 02:17:36 PST 2021
Hi Johannes,
Thank you for your reply.
I don’t know the “real” cause of the slowness. All the map is around 700 mb and it takes time for rendering.
Rest of the team usually have two approach:
- assign different style or categorisation
- copy part of the features in a new shape in order to add fields or, sometimes, merging group o polygon in one entity
Nobody edits the original cartography.
In one hand I was thinking to have a very light wms and in case they need building or road the load as shape (or similars) one layer at the time. In the other hand, having small portion of the city (cropped database) directly as shape (or similar) could be easier for them
Cheers,
Dario
_
Il giorno 26 nov 2021, alle ore 10:31, Johannes Kröger <johannes.kroeger at wheregroup.com> ha scritto:
Hi Dario,
this really depends on the use cases and the reasons for slowness. Some questions to get you started:
Are the rest of the team editing the base map? Its style? Or is it really just a backdrop for them? How often is it updated? You might be able to generate raster or vector tiles for highly efficient access to them if they are static.
Cheers
Hannes
Am 25.11.21 um 19:10 schrieb Dario:
> Hi,
> I was wondering if there is a easier way to manage my city base cartography.
> I have several (around 40) layers, at the moment shape file, representing the whole city.
> As I have a performed computer (for my needs) I use to manage this entire amount of data for my different project.
> The issue is is not so comfortable share my projects with the rest of the team, which waste time waiting for uploading data.
> I see two different scenario:
> - create a WMS without any style customisation
> - crop all the layers within a proper smaller area
> The point is I don’t know how to do and, even more, if is the best approach.
> Thank you for any tips!
> Cheers,
> Dario
> _
> Qgis-user mailing list
Johannes Kröger / GIS-Entwickler/-Berater
WhereGroup GmbH
Eifelstraße 7
53119 Bonn
Germany
Tel: +49 (0)228 / 90 90 38 - 36
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Where2B Konferenz 2021
16. Dezember 2021
im Universitätsclub Bonn und online
https://where2b-conference.com/
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211126/26c8a763/attachment.obj>
