[Qgis-user] MapInfo export issue
Nicolas Cadieux njacadieux.gitlab at gmail.com
Tue Nov 30 13:15:04 PST 2021
I tested exporting a .shp using 3.20.3.  I see no prj file but the file
CRS is correctly positioned.  It's possible the .prj extension was a
temporary fix???  Test in MapInfo.
Nicolas
On 2021-11-30 1:04 p.m., Paul Wittle wrote:
> Hi,
> I was just about to try and push out version 3.16.14 but it has been
> pointed out that if you export to MapInfo tab file it is no longer
> saving the projection in the output.
> Is anyone else finding that the resulting files are doing this and is
> there a work around using say gdal options?
> Sorry if I missed another message about this as I see the Windows
> build has been proving problematic and we are Windows users,
> Paul
> This e-mail and any files transmitted with it are intended solely for
> the use of the individual or entity to whom they are addressed. It may
> contain unclassified but sensitive or protectively marked material and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use
> it, or disclose it to anyone else. If you have received this
> transmission in error please notify the sender immediately. All
> traffic may be subject to recording and/or monitoring in accordance
> with relevant legislation. Any views expressed in this message are
> those of the individual sender, except where the sender specifies and
> with authority, states them to be the views of Dorset Council. Dorset
> Council does not accept service of documents by fax or other
> electronic means. Virus checking: Whilst all reasonable steps have
> been taken to ensure that this electronic communication and its
> attachments whether encoded, encrypted or otherwise supplied are free
> from computer viruses, Dorset Council accepts no liability in respect
> of any loss, cost, damage or expense suffered as a result of accessing
> this message or any of its attachments. For information on how Dorset
> Council processes your information, please see
> www.dorsetcouncil.gov.uk/data-protection
> Qgis-user mailing list
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
Nicolas Cadieux
https://gitlab.com/njacadieux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211130/90d47d38/attachment.html>
