[Qgis-user] Geo Raster Background
L.W.
eaglelw at gmx.de
Fri Oct 1 11:33:19 PDT 2021
nope this isn't what I want ... it is the same as setting transparent
color manually.
I am using PDF and TIF for georeferencing.
Regards
Without no-data-0 or transparent-color:
Set transparent-color to 0,0,0 or use no-data-0:
Am 01.10.2021 um 19:26 schrieb Charles Dixon-Paver:
> I just loaded an unreferenced png with black content into qgis, then
> set the nodata value to 99999, then did a fake georeference with
> arbitrary coordinates, and the result seemed to be rotated without any
> background pixels. Using 3.20 on Windows. The geoereferencer has a
> checkbox for setting nodata to 0, so uncheck that first. Otherwise, if
> you're still unable to get the "triangles" to change, my previous
> messages should still apply.
> On Fri, 1 Oct 2021 at 18:27, L.W. <eaglelw at gmx.de
> <mailto:eaglelw at gmx.de>> wrote:
> yes, maybe to orange, a color that is not in the original image,
> so I can do this color transparent.
> Am 01.10.2021 um 18:25 schrieb David Strip:
>> When georeferencing, aren't the areas outside the original image,
>> eg, the "triangles" resulting from rotation, treated as no data?
>> Wouldn't this issue be resolved by setting the no data value to
>> something other than black?
>> Just guessing here, obviously.
>> On 10/1/2021 2:36 AM, L.W. wrote:
>>> Thanks for answering, but I think this is not the way I want to
>>> go ...
>>> Or, I do not have written detailed.
>>> I have a raster image e.g. a white rectangle, after setting the
>>> points, QGIS rotats this image, let's say, by 45 degrees.
>>> The corners of the imported image are now black triangles.
>>> I do want to have e.g. red triangles ...
>>> Regards
>>> Am 01.10.2021 um 09:50 schrieb Charles Dixon-Paver:
>>>> There's not really any way for a GIS system to automatically
>>>> differentiate between black background pixels and black data
>>>> pixels. QGIS supports users setting custom pixel values to
>>>> render as transparent pixels, but it's left up to users to
>>>> ensure that their data and background values are different.
>>>> From my view, there are a couple of options when it comes to
>>>> fixing this issue in your data. One is to use an image
>>>> processing tool like GIMP or Photoshop effectively, but that
>>>> requires retaining the geographic information and knowing how
>>>> to reprocess the raster accordingly.
>>>> The simplest solution I'm aware of is probably to follow this
>>>> workflow in QGIS:
>>>> * Start a new QGIS project
>>>> * Set all black pixels to transparent in the transparency tab
>>>> of the raster layer properties
>>>> * Digitize a "bounding area" - you can do this with a memory
>>>> layer
>>>> * Move your vector layer to render underneath the raster
>>>> * Give the vector a simple black symbology
>>>> * Use the "Convert map to raster" tool from the processing
>>>> toolbox
>>>> There are a wide number of variations on that workflow that are
>>>> possible of course, but I think that's the easiest to get started.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211001/e813a35b/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211001/e813a35b/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211001/e813a35b/attachment-0001.png>
