[Qgis-user] Join Attributes by Location
    Andrea Giudiceandrea
    andreaerdna at libero.it
    Fri Oct  1 12:40:30 PDT 2021
Hi krishna Ayyala,
what QGIS version are you using?
What you mean with "Exported the joined layer"?
Does the temporary layer "Joined layer" contain any features?
With the options visible in the screenshot, the "Join attributes by
location" algorithn should create a temporary layer with 100 points, not 98.
Anyway, maybe it might be useful if you shared your layers (if
necessary, with a subset or your features) so it could be possible to
investigate the issue.
Best regards.
Andrea
krishna Ayyala Fri, 01 Oct 2021 10:51:18 -0700
> I have used "Join  attributes location" tool on the same layers. Exported
> the joined layer. I see zero records in the Joined layer. Technically there
> should be 98 records. Can someone help me fix this please?
