[Qgis-user] Join Attributes by Location
    krishna Ayyala
    ayyalakrishna at gmail.com
    Fri Oct  1 13:00:35 PDT 2021
Yah. It should create temporary layer with 100 points.. The temporary
layer  "Joined layer" also does not have any features in it. Unfortunately
I cannot share the data .
Regards.
On Fri, Oct 1, 2021 at 1:40 PM Andrea Giudiceandrea <andreaerdna at libero.it>
wrote:
> Hi krishna Ayyala,
> what QGIS version are you using?
> What you mean with "Exported the joined layer"?
> Does the temporary layer "Joined layer" contain any features?
> With the options visible in the screenshot, the "Join attributes by
> location" algorithn should create a temporary layer with 100 points, not
> 98.
> Anyway, maybe it might be useful if you shared your layers (if
> necessary, with a subset or your features) so it could be possible to
> investigate the issue.
> Best regards.
> Andrea
> krishna Ayyala Fri, 01 Oct 2021 10:51:18 -0700
> > I have used "Join  attributes location" tool on the same layers. Exported
> > the joined layer. I see zero records in the Joined layer. Technically
> there
> > should be 98 records. Can someone help me fix this please?
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211001/41acc523/attachment.html>
