[Qgis-user] Join Attributes by Location
Charles Dixon-Paver
charles at kartoza.com
Fri Oct 1 13:24:01 PDT 2021
In that case I think it'll be difficult to troubleshoot without data that
replicates the issue (even if it's fake data). Have you tried the different
cardinality settings available (the "Join Type") to see if something in the
data structure, values, or tool configuration is causing the mismatch
between records?
On Fri, 1 Oct 2021 at 22:00, krishna Ayyala <ayyalakrishna at gmail.com> wrote:
> Yah. It should create temporary layer with 100 points.. The temporary
> layer "Joined layer" also does not have any features in it. Unfortunately
> I cannot share the data .
> Regards.
> On Fri, Oct 1, 2021 at 1:40 PM Andrea Giudiceandrea <andreaerdna at libero.it>
> wrote:
>> Hi krishna Ayyala,
>> what QGIS version are you using?
>> What you mean with "Exported the joined layer"?
>> Does the temporary layer "Joined layer" contain any features?
>> With the options visible in the screenshot, the "Join attributes by
>> location" algorithn should create a temporary layer with 100 points, not
>> 98.
>> Anyway, maybe it might be useful if you shared your layers (if
>> necessary, with a subset or your features) so it could be possible to
>> investigate the issue.
>> Best regards.
>> Andrea
>> krishna Ayyala Fri, 01 Oct 2021 10:51:18 -0700
>> > I have used "Join attributes location" tool on the same layers.
>> Exported
>> > the joined layer. I see zero records in the Joined layer. Technically
>> there
>> > should be 98 records. Can someone help me fix this please?
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211001/bfe89fa7/attachment.html>
