[Qgis-user] Loading geopackage layers in a model
Charles Dixon-Paver charles at kartoza.com
Fri Oct 1 15:44:39 PDT 2021
I think this would be rather challenging to achieve with the graphical
modeler with the current toolset and would be much more readily developed
in a pyqgis script.
Whilst it may be possible (although I'm not entirely sure how), the model
builder tools support for iterators and conditionals can be a bit hit or
miss. Using a python script that is integrated into the model might help
provide the interface you are looking for.
If you are intent on trying to dig deeper into the modeler, a couple notes
would be to use the "multiple inputs", and check out the "conditional
branch" and "filter by geometry" tools.
Hope that helps.
Regards
On Fri, 1 Oct 2021 at 23:39, Nicolas Cadieux <njacadieux.gitlab at gmail.com>
wrote:
> Hi,
> I must be missing the obvious but how can I load a particular layer (or
> all layers) from a Geopackage using the graphical modeler? The idea I
> want to implement is :1) load geopackage from file -> 2)filter all
> layers by geometry type -> 3)save point, line and polygon layers.  I
> can't find how to get a handle on the layers between 1 and 2.
> Nicolas
> Nicolas Cadieux
> https://gitlab.com/njacadieux
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211002/7d0c65c3/attachment.html>
