[Qgis-user] Loading geopackage layers in a model
    Nicolas Cadieux
    njacadieux.gitlab at gmail.com
    Fri Oct  1 21:25:19 PDT 2021
I agree with going the python road. I would normally go with a geopandas as I am not tto good with the QGIS API.
 I am basically trying  to figure out if I am missing an obvious existing tool. I looked at the multiple input.  It  could work with multiple layers that are already opened but my initial idea is to do this from the geopackage so layers are not yet opened.
Thanks for the input
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 1 oct. 2021 à 18:44, Charles Dixon-Paver <charles at kartoza.com> a écrit :
> I think this would be rather challenging to achieve with the graphical modeler with the current toolset and would be much more readily developed in a pyqgis script.
> Whilst it may be possible (although I'm not entirely sure how), the model builder tools support for iterators and conditionals can be a bit hit or miss. Using a python script that is integrated into the model might help provide the interface you are looking for.
> If you are intent on trying to dig deeper into the modeler, a couple notes would be to use the "multiple inputs", and check out the "conditional branch" and "filter by geometry" tools.
> Hope that helps.
> Regards
>> On Fri, 1 Oct 2021 at 23:39, Nicolas Cadieux <njacadieux.gitlab at gmail.com> wrote:
>> Hi,
>> I must be missing the obvious but how can I load a particular layer (or
>> all layers) from a Geopackage using the graphical modeler? The idea I
>> want to implement is :1) load geopackage from file -> 2)filter all
>> layers by geometry type -> 3)save point, line and polygon layers.  I
>> can't find how to get a handle on the layers between 1 and 2.
>> Nicolas
>> Nicolas Cadieux
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211002/dd764490/attachment.html>
